Noise from driver side window or door.
I'm hearing a fluttering sound coming from the driver side door or window on my 2004 RX 330. I think it's caused by the wind blowing against the window. When I push firmly on the window, the noise stops. Any fixes or tsb's out on this...? Thanks.
Yes... search the forum for this problem.
The window over-compresses the rubber seal, which affects the way the seal sits in the door frame, causing an air leak. If you open the window just slightly - enough to reduce the force on the seal - the noise will stop.
If I recall correctly, someone posted that there is a new seal that cures it.
I had a TSB done on Tuesday 3/15/2005 regarding to the wind noise. But I still can hear the wind noise. If I tap down a little bit, the noise is gone. I also notice the window is still tilted like before if I roll it all way up. Does anyone get a second fix to make the noise gone?
TSB: NV0008-04
68171-48032 Weatherstrip, Fr Door
68172-48032 Weatherstrip, Fr Door
Thanks.
TSB: NV0008-04
Thanks.
I just got this done as well today.
NV008-04 FRONT DOOR WIND NOISE IMPROVEMENT:-
12/22/2004 - 2004, 2005 Lexus RX330. Some vehicles may exhibit wind noise coming from the front door side window glass. 68172-48032 Weatherstrip, Fr Door
