2005 RX 330 AWD What kind of motor oil......?
Originally Posted by Lextranny
Does Lexus requires synthetic or regular motor oil? What's the grade? 5w-30?
Thanks!
Thanks!
Lexus Connoisseur
10w30 will work fine in CA climates. Unless you live in the mountains that is.
What does the manufacturer recommends using though? Synthetic or regular?
I guess for California 5w-30 will do.
10W-30 is old school oil for today's newer fuel efficient engines! Stick with 5W-30 or even )W-30 will not harm a thing!
The only thing 0W-30 will give you is even better start up protection cause its a little thinner---so it gets moving sooner, still a 30W oil when its warm
Originally Posted by Lexusfreak
Lexus recommends using regular oil Lex, but as mentioned before either is fine as long as it's the correct viscosity.
Originally Posted by jayskinner
Don't forget the API rating of SL as well as the 5W30 viscosity.
Lexus Connoisseur
Originally Posted by flipside909
That's such a factless myth.
Lex, the answer is no.....synthetic does not increase horsepower.......it protects better as it does not break down over the course of an oil change like conventional oil does over time & is much better in very cold weather to name just a couple of benefits.
soda7o
11-05-11 08:56 AM
