04 RX330 check engine light
Anyone else get a check engine light, VSC light, and Trac Off light come on all at once? Our 04 RX330 with 33K miles (Bought in April 2003) just popped up all 3 lights. I'm sure it is all related (Probably a speed/wheel sensor). The dealer can't take the car in until next Wed, but they informed us that it should only take a day and they have seen this same problem before. Unfortunately they didn't go into any details on what that problem is. Anyone else have/had this same problem?
My best guess is the Brake Assist feature has failed.
Don't confuse BA with normal power brake. BA kicks in when the RX notices that you want to make a sudden stop. It gives you extra boost in braking power in case you didn't floor the brake pedal.
The most common cause of this on the RX300 is the vacuum hose behind the air filter box coming off the metal tube below it. Did a quick lube place just change your oil or did anyone check the air filter? Do a search here on check engine light for a lot of info. This may also pertain to the 330.
ust a follow up. The earliest my dealer could take me in was 1 week after I called them about the check engine light. During taht week the lights all went off. I figured the codes would be stored, but when my car finially was checked they said no codes were found and they couldn't do anything. So basically nothing was done and no diagnosis was made. I'm kind of worried about that since my warranty is about to run out sometime later this year. Knowing bad luck it will come back again and I'll have to pay for the fix the next time.
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
Originally Posted by CK6Speed
Knowing bad luck it will come back again and I'll have to pay for the fix the next time. ![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
Are you up for buying another Lexus after this? I'm actually second guessing it.
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
Originally Posted by NeverSatisfied
Do you think this is "first-year jitters"?? I haven't had anything like that happen, but I always seem to have trouble w/ the 6-disc CD player. My IS had its player changed out twice! And now my RX is getting it changed out for the first time.
Are you up for buying another Lexus after this? I'm actually second guessing it.![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
PS. I'll be entering my RX330 in the August car show. I'm building it right now so I'll send you some pics of it when it is done later in August if you remind me. It won't be completed, but it will be somewhat different. Once I get more money I'll do more things. For now it is just a drop, Alpine A/V system with PS2 and DVD, 20" rims, color matches spoiler and lower body trim and I just installed the color matches running boards I bought from Darrell as Sewel Lexus.
As you know I'm an Acura/Honda and Toyota/Lexus fan. I more than likely have no problem purchasing another Lexus, but it also depends on what Acura has as well. I really do like the RL, but I also kind of like the GS. Both have strong points and weak points to them. If it were right now today, I would get the RL simply because the interior is as good as my Lexus or better than even the RX330 IMHO, performs as good if not a very minor edge in performance over the GS300 AWD, but one big major reason is Acura offeres navigation in Hawaii where Lexus does not. That alone moves me from two closely matches car to the RL. Otherwise, if the GS350 comes out and Lexus offers navigation, I'll probably sway to the GS. Another thing to note is I give up on buying new cars. I'll probably go back to buying CPO used cars. More bang for the buck and I can use the saved money for modifications ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
I hear ya on that! The RL is very sweet and a few grand cheaper too.....
I cant wait to see picts of your project 330.....what color do you have?
I'd love to see pics of this. The only one I've seen is the Lexus chrome sidesteps, which I think look nasty on the 330.
I have a Neptune Blue Mica. As I mentioned above, I'll start a new topic with pics.
Out of Warranty
I'm not aware of any other problems, but just had 30K service performed last week. The car is an '04 (puchased May '03) has 31K on the clock, and one of the early units produced in Japan.
Any Ideas? CK, did you have any further problems?
I had the same thing happen on my 2005 RX330 after I had the timing belt changed @ 92K. Check the timing belt components. Timing may be off by a notch or 2.
Super Moderator
Welcome to the Club.
This is an old thread. What would have been done in this situation is to use an OBD2 scanner to pull the code and that would help locate the issue. I usually have found this is a P0171 error.
Will close this thread.
sirhchris
02-07-18 10:12 PM
TerryTCL
02-18-04 06:06 PM
