Motor oil 5w-30
Old 01-31-05, 03:32 PM
parula
parula's Avatar
Lil4X, I am sticking with a 5k change with a major full synthetic, so far, so good.
Old 01-31-05, 08:45 PM
TunedRX300
TunedRX300's Avatar
Lightbulb Compulsive oil change damages engine
Originally Posted by TunedRX300
I found this link very helpful.
http://www.vtr.org/maintain/oil-overview.html
Oil Filter is also important. Your engine oil may still have life but if the filter is clogged, bypass valved will be activated and oil goes back unfiltered.
"Engine wear actually decreases as oil ages. This has also been substantiated in testing conducted by Ford Motor Co. and ConocoPhillips, and reported in SAE Technical Paper 2003-01-3119. What this means is that compulsive oil changers are actually causing more engine wear than the people who let their engine's oil get some age on it"
Quoted from a very informative study done on Mobil 1 5w30.
http://neptune.spacebears.com/cars/stories/mobil1.html
Old 02-02-05, 08:52 PM
Lexusfreak
Lexusfreak's Avatar
Cool
Originally Posted by Booyah
So how long do you go between oil changes?? I know Amsoil totes there oil as changing at 1-Year or 25,000 miles??
I run the Amsoil 0W-30 and filters
I will be using the Amsoil ASL series 5W 30 along with the Amsoil heavy duty oil filters. Twice a year (or every 6 months) I will be changing it.
Old 02-04-05, 09:42 AM
RXGOLD
RXGOLD's Avatar
Thanks....y'all...I got some OEM oil filters.....and Mobil 1. Will do oil change this weekend!
Old 02-04-05, 02:11 PM
MR_RX300
MR_RX300's Avatar
I started using MOBILE 1 after the first dealership free oil change, I believe they put in cheap s@%#% and charge you an arm and leg I am sure.......now I go to a private foreign car shop to get my changes...I "BMOO" thats...Bring MY OWN OIL....hehe
Anywone know what Dealerships charge for a Lexus oil filter..I need to put some up..maybe an air filter too!! any have any prices? thanks,
mike
Old 02-04-05, 06:18 PM
TunedRX300
TunedRX300's Avatar
mike
Another member posted that Lexus uses recycled motor oil to save cost. If it is true, there is another reason not to go to dealer.
Old 02-04-05, 09:24 PM
Lextranny
Lextranny's Avatar
Recycle motor oil!! Ouch!!!!!
Old 02-04-05, 09:29 PM
Booyah
Booyah's Avatar
I find that Lexus uses recycled oil very hard to believe.......
Old 02-05-05, 10:03 AM
TunedRX300
TunedRX300's Avatar
wwest posted this in the other forum.
"OIL does NOT wear out!
Neither engine lubricating oil nor transmission hydraulic fluid.
The primary reason you change your engine lubricating oil is because it becomes contaminated by the by-products of combustion. Before changing my engine oil I run the car to the point where it is up to temperature. That allows the oil to pick up and hold in suspension most of the particles that have settled into the sump.
Engine oil can, and often is, recycled many times and reused. Most dealers, even Lexus, buy recycled engine oil in bulk in order to cut costs.
Transmission oil is more in the nature of hydraulic fluid than it is for lubrication. Transmission fluid is formulated specifically to allow particles to settle out of the oil and into the sump, as it would be detrimental to the long term reliability for it to hold then in suspension.
For the person who had a filter clogged with metalic particlles my guess would be that you are looking at more problems soon down the road.
The primary source of debris of this type is the result of wearing of the clutches and bands, material very much like that of your brake pads.
I can't even estimate how many miles I have driven since 1961 without ever having changed or flushed transmission fluid absent work on the transmissions. Work that was mostly overhauls at 100K plus. "
Old 02-11-05, 06:58 AM
HarrierAWD
HarrierAWD's Avatar
Just about everybody does. Even brand name oil off the shelf is mostly recycled oil. (Where did you think the used oil go? The ocean?)
Old 02-11-05, 10:31 AM
TunedRX300
TunedRX300's Avatar
Used oil is perfect for cooking
Old 02-11-05, 05:59 PM
HarrierAWD
HarrierAWD's Avatar
LOL. No wonder many gas/service stations have their own fast food joints nowadays.
iseeu1001
03-03-16 05:36 PM
got56ry
09-15-08 11:40 AM
Intellexual
Maintenance
07-26-01 07:53 PM
Quick Reply: Motor oil 5w-30
