Another Question with Comment about the RX 330
I am curious about the Sunroof operations on the RX 330.
And maybe I need to read the manual , which I haven't really had time to do since I bought it.
I Noticed something with the RX 330 that if I recall was available on the RX 300, the sunroof was a one touch operation when opening it all the way. I have tried several things with the RX 330 switch, like holding it down for an extra second and using the other switch and it still seems that to open it you have to hold the button down.
Has anyone noticed this too or am I missing something. Or should I just make time to read the manual..... lol....
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
You're not missing anything... it's supposed to be one-touch operation. Sounds like the dealer didn't initialize it properly during the pre-delivery setup.
Here's how to initialize it:
1. Turn the ignition switch to the “ON” position.
2. Push and hold the buttons while performing the following operations:
- Close roof
- Full tilt up
- Full tilt down
- Full slide open
- Full slide closed
3.That's it! Verify that one-touch open and tilt both work.
The power back door and power windows also have similar initialization sequences. The computer just needs to "learn" where full open and full closed are on the motors. Of course, it's tested at the factory, but the battery power is disconnected for transportation to the dealer.
- Close roof
- Full tilt up
- Full tilt down
- Full slide open
- Full slide closed
Are you referring to the normal one-touch operation of your sunroof or the extra 1/2 inch your can retract the sunroof if you push the sunroof button again?
If you push the sunroof button and the sunroof does not do the one touch operation then go to the dealer.
I don't know if anyone else has noticed, but once your sunroof has gone all the way back, if you press the sunroof button again, the sunroof panel will go back another 1/2 inch.
It is the same with my '01 IS300. check it out if you have not already tried it.
Thanx man, I finally had time to sit in the vehicle and do all those steps and get the sunroof to do what it is suppose to.
So now I have the one touch open and close thing working, and yes I knew about the extra inch or so that it opens when you touch the button again. That was the same thing on my RX300. I should know I practically wore that sunroof out cruisin' the beach ever summer. Well, practically anytime it was warm here and as well as having old dog out cruisin after a session in the surf.
Looking forward to cruisin this one after a morning session , when I get my body kit from Japan,
( oh yeah that is right......oops did I say that ' body kit' out loud
Peace
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
![Agreed](https://www.clublexus.com/forums/images/smilies/boink.gif)
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Peace
Out of Warranty
I think I just blew all my Valentine's Day points . . . I'm going to go hide now . . .
actually I was refering to the Old RX300 that was a victim of reality, and the New Dog is the New RX 330 it's replacement. (sorry to hear you call your significant other the ' Old Dog')
lol
lol
Originally Posted by RXGOLD
Yes, I have the same issue as you. Pressing it again, it opens back another 1/2 inch on the sunroof. Does everyone have the same problem? Or this is the way it supposed to work???
It has to do with wind entering the vehicle. Believe it or not, that extra 1/2 inch causes a disproportionate amount of wind to enter the car, and reduce efficiency.
