Fuel Injector Noise
The TSB stated on my work order was EG0050-05. It states the following: Fuel Main Tube and Fuel tube clamps along with second Fuel Pressure Pulsation Damper Assembly. All of the ticking is gone. It's great to have it sound like a Lexus instead of an old Chevy.
Originally Posted by wing0
I brought my RX300 in too, and they wrote this...
"There is an update to reduce noise level. Needs to replace fuel pipe, damper and gasket"
So they said would order the parts and book me in for the fix.
Is this the same type of fix as the RX330?
Just looked in the system again and found it. Listed under TSIB EG004-05. Details look the same as the fix for the RX330. Should work nicely.
Hello everybody...
My dad just took the car for the repair(finally they have the parts) and I especially asked the advisor to print me the TSB.
This fix applies to 2001-2003 RX300 and was released on March 11, 2005(quite new...almost the same time as the RX330 fix).
TSB2095: Engine Mechanical
Title: Fuel Injector Ticking Noise
Introduction:
Some cusomters with 2001-2003 model year RX300 vehicles may complain of a "ticking" noise from the engine compartment when the engine is idling. Updated fuel main tube and fuel tube clamp are now available. In addition to updated parts, a second fuel pressure pulsation damper assmebly has been added to imporve this condition.
Hope this helps those that are having the "ticking" noise problem. I will be driving the car soon to verify that it did fix the problem.
Introduction:
wing0, thks much, this has been a longstanding problem they told me was normal for the car. I am really glad they fixed it,
and my car just started making a whirring noise that rises in pitch with RPM, same in neutral - hoping this is related to the TSB2095.
I'd say get both things checked...
Good idea on the vacuum tightness I'll check that out. I am sure I have the injector noise - that loud ticking sound one can here through the firewall into the cabin discussed on several threads here.
JamesHuang
01-16-12 02:46 AM
wing0
RX - 1st Gen (1999-2003)
02-17-05 02:00 PM
