lexus 15k service??
Hi all! I just joined club lex but I've owned my RX330 since Jan 2004
but yeah I just got my 15k service... $284.00 yikes... all I saw them do was: change the oil, change air filter(s), rotate tires (NO BALANCE), and wash the car... perhaps I should only do major services at lexus.. I thought it would just be an oil change.. like 100 bucks max for this service!!! I didn't even get a loaner!!! (I'm only 19... ok so wat) but ya otherwise i like the car!! kool um thanks!
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Yes, there are lots of threads about how overpriced Lexus service is. To add insult to injury, the "service consultants" often add things that aren't required by the maintenance schedule. You should be able to say, "I need the 15K mile service", but you can't - every dealer makes up their own version.
Even a Toyota dealer is usually more reasonable than a Lexus dealer. The same engine is used in the Sienna, Highlander, and Camry, so most maintenance tasks are no problem for Toyota. The only thing a Toyota dealer can't do is warranty work.
Not only Lexus add all kinds of junk to the service menu, they refuse (politely) to do items mentioned in the owner's manual. Such as re-torquing the drive shaft and including the spare into tire rotation. What gives?
Toyota ExpressLube is my new best friend.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
These guys are all pushed and rewarded for sales of services. I guess things like adding the spare in the rotation adds time but no value to the reward program. IMHO, some of the stuff I read about could be considered borderline fraud.
Out of Warranty
but yeah I just got my 15k service... $284.00 yikes... all I saw them do was: change the oil, change air filter(s), rotate tires (NO BALANCE), and wash the car... perhaps I should only do major services at lexus.. I thought it would just be an oil change.. like 100 bucks max for this service!!! I didn't even get a loaner!!! (I'm only 19... ok so wat) but ya otherwise i like the car!! kool um thanks! ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
I recently took my 2RX in for a tire pressure warning light that was acting strange . . . I thought. They found a small nail and fixed the flat, road tested the car and gave it back - all in about an hour (they even offered a loaner). My bill? Zip, zero, nada!
That's the kind of service you are looking for!
FWIW, Discount Tire Co. always fix flat for free if you buy the tires from them.
And most service stations fix flat for $5 - not worth their time, but they just do it for the common good I guess.
I expect Lexus dealers to give me a good price for factory recommended maintenance. If they want to add "value," they should be separate "add-ons" or "come-ons" on the menu, not part of the package. Most importantly, they should not make up all kinds of excuses not to perform factory recommended maintenance items.
Got a question for you all..
My RX330 is approaching the 15k mark, and I called Meade Lexus of southfield to check how much the 15k service was, before taxes almost 400 dollars.
My question is, my friend has a top notch oil change establishment and said he could do a complete mobil 1 synthetic oil change, mobil one filter, the works, for alot cheaper then 400. Like buy the oil and filter and give him some cash..
Now what do Lexus perform on 15k service, anything that a normal oil change wouldnt do?
I am just wondering if i should have lexus do this service, or go synthetic from non lexus service.
Thanks!
Thanks!
Unfortunately, you'd have to ask the dealer that gave you the price quote what they would do.
As we've said before, there is no standard "15K mile service" - each dealer makes it up, and it usually doesn't correspond exactly with what's in your maintenance book.
At 15K miles, the 2004 RX330 book says to:
Inspect: Brake pads, brake lines, steering linkage and boots, rack and pinion ***'y, ball joints, drive shaft boots, transfer case oil (AWD), rear diff oil (AWD), exhaust system mounts
Replace: Oil, oil filter, cabin air filter
Also: Rotate tires, torque nuts/bolts on chassis, inspect engine air filter (if it's 12 months old)
Welcome to the club. Here's hoping you're a " quick learner ". I hope the dealer used protection and you both enjoyed that cigarette afterwards!
check ur local toyota dealer. When i bought my lexus i was told I can actually have it serviced in the toyota dealership. Well thats what I did with the 10 k check and i paid half of what lexus would have charged me. lobby is not as nice as lexus and theirs no car wash. Major maintence scheds will also save me $100 more later. They follow same checks as a 4 runner!
