rear view camera
Hi,i was putting the reverse on my rx330 and the navigation screen went black and didnot show any picture from behind,i looked at the setting every thing looks good.Any information please.
There's a TSIB for this problem. TSIB # EL003-05, "No Picture Displayed From Backup Camera", was issued on April 6, 2005, for the 2004 RX 330, GX 470, LS 430, and LX 470. Problem is a bad camera - solution is to replace the camera.
For the RX 330, this TSIB applies to serial numbers below these:
Japan 2WD: 25394
Japan 4WD: 49572
Canada 2WD: C004438
Canada 4WD: C006588
The serial number is the last 7 digits of your VIN.
Japan 2WD: 25394
Japan 4WD: 49572
Canada 2WD: C004438
Canada 4WD: C006588
Hello!
I own RX330'2004, bought in Miami. Start getting the same troule -rear view camera stop showing anything. Where can I obtain the information on thr fix?
I am living in Ukraine and here is no official Lexus dealer and local Toytoa doesn't provide any support for Lexus cars.
Many thanks in advance!
Yevgen
Ps I also got troubles with nav screen calibration. Is it possible to check it somehow?
Yevgen
Originally Posted by dhamaka127
I know this question might be a stretch..but here it is anyways....
Is there a way to have the rear view camera on while in drive?![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
TSB or not, the '04s are still uner warranty, so if the camera fails, you get a new one.
Or am I missing something?
(PS: My J-AWD Serial # is way below the cutoff number listed above, and after 40,000 miles is still working fine -- but I'm sure they are not ALL failing.)
Yes you are covered
Yes---you have to hack into the service menu and override the camera and it will stay on! Easialy done, search button
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I also start getting troubles with navigation screen adn, according to techinfo.lexus.com I should reinstall a new one.
Who knows where can I order a new camera and display unit for a reasonable price?
Yevgen
the same is mine. I also should to change multi-display assy (what does this assy mean?)
- I already changed one of Mark Levinson speakers (front left)
- my rear entertainment system reads 1:10 disks
- I want to change my steering wheel as the leather went away times ago
- I changed twise the breaks because of the strong vibration during the braking....
Still I love my car
Still I love my car
Got mine fixed today
Concern: cust states backup camera shows a blur
cause: open circuit
correction: r&r backup camera
lex 86790-48020 camera assy televis
custs states ac light flashes on
cause open circusit
correction: abnormal function of ac meter/headlamps 04-05 rx330 tsb
lex 82721-48050 block, engine room j.
what the hell does that mean?
cause: open circuit
cause open circusit
