RX 330 Display problem
Hi,
Has anyone experienced a problem with the multi-display panel on an RX300? The display on my 2001 goes out intermittently. It seems to be getting worse. The audio system does not work when the display goes out. The heating/cooling system still works but no information is displayed.
Thanks,
Chuck
Thanks,
Chuck
I have had the display (99 RX300) go out on me a few times ... less than 5 times in life of ownership. It always comes back if I turn off ignition and then later trun it back on. [aka system re-boot].
If happens more frequently than once a month, I would start by cheking simple things like loose battery conector, failing battery, fuse not seated properly etc. Else time to visit the dealership.
Hope this helps.
Salim
Hope this helps.
Salim
Originally Posted by chuck4014
Hi,
Thanks,
Chuck
Thanks,
Chuck
Lexmex
RX - 1st Gen (1999-2003)
12-29-08 08:06 AM
2001, 2002, 300, 300multidisplaylighting, 99, display, displayproblem, lexus, multi, multidisplay, panel, problems, rx, rx300, working
