RX330: Transmission Oil Drain Capacity
Old 08-09-05, 06:53 AM
lexsg
lexsg's Avatar
Default RX330: Transmission Oil Drain Capacity
Yesterday, my mechanic drained the tranny oil, and topped it up with about 4 quarts of Type-IV. Is this the correct capacity? I had the impression (don't remember from which thread) that it is more than this.
Thanks in advance.
Old 08-10-05, 07:58 AM
Tammy
Tammy's Avatar
Sorry for the delay.... The drain and fill is 3.8 Qts for FWD and 4.2 for AWD.. Check with engine running after engaging P thru 2 then back to park. There are cold and hot marks on the dip stick.
Old 08-10-05, 07:57 PM
TunedRX300
TunedRX300's Avatar
For AWD the capacity is 16 qts, but you can only drain 4 qts. It is not a good idea to mix non-Toyota ATF with Type IV, especially still under powertrain warranty.
Old 10-14-22, 06:16 AM
Rx330fnboi
Rx330fnboi's Avatar
it says right in the service manual the capacity for atf is around 9 liters not 16 quarts!
river
RX - 1st Gen (1999-2003)
08-31-17 11:06 AM
bagsbie
07-07-09 03:45 PM
vu0219
02-10-08 11:38 AM
Ariyanna
07-13-07 09:38 PM
BananaGS
Maintenance
14
08-05-02 01:13 PM
Quick Reply: RX330: Transmission Oil Drain Capacity
