Reprogramming Auto roll down feature?
Anyone know how to reprogram the auto window roll down and also the 1 touch sunroof features? I had to disconnect my battery for a few hours and lost those programed features. I somehow was able to regain auto roll down for all but the front passanger window which I can't control from the master switch as well now either.
Thanks. I just reprogrammed everything. Side note. The sunroof is rather easy. All you have to do is hold down the sunroof tilt up button. What this does is automaticlly perform the tilt up, tilt down, open, close procedure. Once done let the button go and try the slide button and all the one touch open close features should be working. For the windows, for some reason all 3 windows except for the front passanger window got reprogrammed. What I had to do for the front passanger window was perform the roll down and hold, roll up and hold procedure on that window itself, then the auto roll down now works as well as control from the drivers master window switch.
Originally Posted by rxdriver
Seems like you know a lot.....do you work for a Lexus Dealer as a mechanic?? Great info.. thanks!
I want to take this opportunity to mention that if you have a 400h and the 12 volt battery has been disconnected or replaced it can cause poor mpg and engine performance unless the dealer reprogramms it after the new battery is installed.
Originally Posted by Lextranny
Rxdriver,
