RX330 Sport Equipment
#32
Originally Posted by JZA80MHU38
Given the weight differences between a 4-cylinder (2.4L) and a 6-cylinder (3.0 and 3.3) and the hybrid (engine, motor plus battery pack), their suspensions should have different spring and rebound rates, hence different part numbers. The shocks and springs from the 2.4L will very likely "fit" to teh 3.0/3.3L, but it may bring negative effects to the handling.
http://www.tein.co.jp/wadamp2te.html
The chasis codes are different between FWD (MCU10W) and AWD (MCU15L).
#33
The new H&L sport springs did lower my 2004 RX330 by about an inch. I like the slightly lowered look and I'm using standard original shocks.
The main complaint was nose dive during braking. It's now about 75% better.
Secondly the side to side sway was more than I thought safe. The new springs might have improved this by 35%.
The ride is stiffer and you feel some bumps. After driving a week, I only notice at road imperfection. (I'll slow down for railroad crossings).
Overall I'd do it again.
The cost was approx. $300 for the sport springs and another $455 to install.
Next up would be a stabilizer bar to improve side to side dip at corners.
Anyone try that one yet.
