Adjusting Fan Speed
I have a 2005 RX330 w/Navigation and am dismayed that the only way to adjust climate fan speed is via a three step procedure using the navigation screen: Climate | Fan Speed, followed by pressing another button to return the screen to its prior state. This necessitates taking your eyes off the road for several seconds while executing the sequence of screen commands; this annoying and dangerous. I think this awkward procedure is at odds with Lexus' other purported safety implementations: a crude block that prohibits entering navigation commands while the car is in motion and a complete block of phone dialing while the car is in motion. In pains me to think that Lexus forgot to include a simple fan speed **** in a $40K automobile!
Steve
Steve
no offense, but why dont you use auto air? I dont notice the "problem" in my prius at all although I usually keep it at auto air... Screen buttons are very large and easy to use.
spwolf, you really need to sit in one of these RX to feel the "hurricane". Wind blows like crazy no matter what temperature you set the auto-climate control at, especially when the outside temperature get extreme.
I usually will just adjust the slot flip to the side so it's not going to blow air into my face, till the other passengers complain about it. Yes I appreciate the reliable A/C on Japanese cars but the RX is just way too strong in blowing winds.
If you're suggesting that I always run the AUTO mode and rely on the programmed defaults for fan speed, that is not acceptable. There are many times when I choose not to drive in AUTO and run the A/C, e.g., like the cool, dry days we had the past six weeks before the rains hit.
Steve
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Steve
MultiTasking Mom
funny thread.
here are two suggestions:
(1) Auto setting, as spwolf mentioned. if it's 90 degrees outside, and you want less air, just adjust the air temp upwards. it sounds counter-intuitive, but it works. we do this in the RX and GS because we don't want to use the nav screen all the time. even though it may be 90 outside and the thing initially blasts in your face, turn it up to high 70's and the fan speed goes WAY down (all the way to low) - the air is still cold (it's all relative anyway) A/C and cools down the cabin. if the cabin temp later becomes too warm, turn the auto temp up a bit and the fan will go faster... i think it works pretty well, no complaints here. the other thing, if you have voice recog nav (our GS does, but not RX), you can tell the thing what temp, making the auto setting even better and truly hands free. so i get in the car and say "78 degrees" and the fan speed goes way down; and Yes, the air is still plenty cold and comfortable.
(2) decide what screen setting you want and adjust the auto-transition accordingly. if you adjust the temp alot, then turn off the auto transition and keep it on Climate while you drive. if you like watching your little nav arrow move along the roads most of the time, turn on the auto-transition and that saves you one step to get back to your map.
Originally Posted by lexuslover
funny thread.
I must admit, all this monkey business shouldn't be necessary when a simple dash-mounted control would be more intuitive and work fine.
MultiTasking Mom
Originally Posted by SteveRX330
I'm not familiar with this setting. Is this something I can set as a default or does the dealer need to do this with his handheld? Thanks.
This is a bit of a stretch, but what does the Prius have to do with the RX330 and its dashboard design?
Steve
Steve
I have to say that I much preffer it to Prado/GX interface which has fan speed on the buttons as well however it has soo many buttons that it is quite hard to use whenever I drive it. I preffer simplicity of RX setup which is quite similar to my Prius.
of course, you have to adjust to it as lexuslover said but I i found it intuitive rather than distracting...
Lexuslover:
I don't see the "Adjust Auto Transition" under the Menu screen. Perhaps your navi is slightly different than mine (I have a 2005 RX330).
But let's not lose sight of my principal issue: I would like the capability to adjust my fan speed without having to a) run my AUTO A/C, and b) without having to press multiple navi screen buttons. Lexus has gone to great lengths to preclude drivers from using the navigation and telephone features while the car is in motion; why, then would they force you to press multipe navi commands to change something as basic as fan speed??? Shame.
Steve
it's in the MENU button functions
Steve
MultiTasking Mom
sorry, my fault! it's in the INFO button, screen transition settings. your version is probably different from mine (04 RX's have the Gen 3 nav system, '05 and up got the Gen 4 w/ Bluetooth). i double checked in the 06 GS, which has Gen 4 nav, and it's in the INFO button also.
try it out, you will like it much better. you are right, an individual button would be nicer, but i think once you turn off auto transition, you will be much happier. you get so used to where the buttons are after a while that it becomes 2nd nature anyway.
enjoy!
After pulling into the garage tonight I found the Auto Transition setting under INFO | DISPLAY SETTINGS. I turned it ON and will test it tomorrow.
I stopped by my dealer today to check on my Title and Registration. In conversation I asked if anyone has ever commented on the lack of a fan switch. He said no, and asked why I didn't run the AUTO setting and forget about fan speed. I explained that there are times I don't want to run the A/C, mostly in an attempt to conserve fuel. He replied: running the A/C has minimal effect on gas mileage during the fall, winter and spring seasons when the outside temps aren't very high.
Two thoughts come to mind. First, I'm having a little trouble believing that running the A/C during the non-peak summer season has minimal effect on fuel consumption. I would appreciate hearing comments from others on this one.
Second, given the above, am I just being thick headed not wanting to run the A/C all the time???
Steve
Steve
MultiTasking Mom
wait, you want to turn the transition OFF to get your desired effect.
ON - display goes back to nav map after a few seconds of being on climate screen (factory default)
OFF - display stays on climate screen until another screen is selected
i agree w/ the dealer re: a/c. most people think a/c is for cold air, but it's really not. it takes the humidity out of the air, and i pretty much have it running all the time, just at different temps. for instance, tonight we were out and about and had it at 77 degrees a/c. if i just turn a/c off, pretty soon my windshield and windows will fog up. that's why AUTO works well, because i keep the a/c on all the time to keep the "mugginess" out of the cabin.
also, i hardly notice a change in MPG throughout seasons. even though blasting AC in the summer seems like it should use up more gas, i don't notice a real change in mpg. mpg is mostly affected by driving style and traffic conditions, in my experience.
Steve
Steve
AUTO is designed to keep the air flow at a minimum amount and will only increase the fan speed when deemed necessary. (if the temperature is about 10(?) degrees off from the desired setting/set point, such as when you first start the engine). Unless you have all the windows open, I doubt the fan will ever increase in speed once the temperature range has been achieved. It quickly recovers and then gently goes to LOW, and you dont have to touch a thing for the rest of your journey. Having a dial would defeat this excellent feature.
As far as it being like a hurricane when it's trying to recover (initial startup on a hot day), it does have a powerful fan. One thing I have noticed is that if you open both the left and right dampers, it won't be so bad. If you close these, it's liable to blow you into the back seat!
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
If you like AUTO and don't want it to automatically change the fan speed (based on conditions), why not lock it in to a particular low speed? Hit AUTO, then CLIMATE and pick the desired speed. It will remember this, even after you turn the vehicle off and on again. The auto light goes off, but it still remembers the other settings.
If you like AUTO and don't want to run the a/c pump, why not turn it off? Hit AUTO, then CLIMATE and touch the A/C button. It will go off and the vehicle will remember the other settings, even if you turn it off and on again. Everything else will still be auto.
At least that is my understanding of how it works. It's very flexible and efficient.
Best regards
Mike
