How much will 245/40/20 tires improve the RX330 handling?
I have a 2WD 2004 RX330 with H&R lowering springs installed. The springs eliminated some of the float while cornering. It is time for new tires and I am considering installing 20x8.5" wheels and 245/40 street tires (G Force TA KDW or PZero) tires. I was wondering if those of you with upgraded wheel and tire combinations experienced a noticeable improvement in cornering capabilities after the install.
Thanks.
Thanks.
I have a close set up to what you are thinking about except our 04 FWD RX330 is on Eibach springs, and the tires are different. My rims are also 20X8.5+20 offset, but the tires I'm running are taller than stock diameter at 255/50/20 as oppposed to the 245/40/20 you want to run. What this means to me is that you might get a little more cornering grip because of the smaller side wall and less side wall roll, but I doubt much. For me, I added the rims and tires 1 or 2 days before I installed the springs. From my memory, the handling improved slightly. It was enough to notice, but not really enough to transform the car. The springs really made a much bigger difference. So, if we put that on a scale and call the springs 100% improvement, I'd say the rims and tires were about a 50% improvement.
Thanks.
Thanks.
Originally Posted by CK6Speed
Try this link
http://www.pbase.com/chrisk/rx330
Originally Posted by TunedRX300
You will handle better, but be careful with bigger rims. They look cool but unsprung weight will increase, that is bad especially at wheels since additional weight are mounted at moment arm and being multiplied. Acceleration will suffer, so is braking. Go for forged rims for better strength and lower weight. For the same matter, be careful with bigger tires, with 20" rims, every pounds you add will be multiplied even more.
The other option I am considering is changing to 255/50-18 performance street tires to replace the stock all season Goodyears. Since it is only a FWD model and I live in Los Angeles, I am mostly shooting for improved dry weather handling and don't need to worry about rain or snow.
Originally Posted by joedaddy1
your best option would be to trade the RX for the FX
Even better would be the new...
Jeep Grand Cherokee SRT8. There was a review of it in one of the car books and it's a better looking, better perfoming Cayenne S for about $45,000.
Try this link
Originally Posted by Frankr66
what wheels are those???
The rims are TSW Montage in 20X8.5 +20 offset. The Lexus center cap just barely fits on the rim. The Lexus caps are just a hair smaller in diameter so they don't fit real tight, but tight enough to not fall out.
Mpg
Id rather get an Audi S4 or even a Dodge Magnum (if it came with a manual transmission)
Lowlexus
09-10-10 01:52 PM
