RX350 Questions / Speculation (merged threads)
Originally Posted by ToyoLexus
More interested in any:
Cosmetic Changes
Generation 5 Nav?
Change in stereo - i.e. sat availability or iPod hookups?
Push button start?
Jay, Lexus has nearly lost my Dad's business over the RX. He was ready to buy a new 2005 last summer but a dealer in Richmond called headquarters for him to find out if the 2006 (only a few months away, at the time) would have XM built-in.... they said it would be, so he waited until September for it to come out. Then they told him it wouldnt be until January, as XM radio would be late availability, so Dad waited a few more months since they said it would "definitely be available in Jan". December comes and they tell him it wont be until "early March" and will be a new model, the RX350. Long story short, sat. radio in early March, but by now we dont trust anything they've been promising.
Sorry if you're discouraged, but anyway XM is at least in the planning stage.
Cosmetic Changes
Generation 5 Nav?
Push button start?
The only 3 things that we really want should be available: more power, nav (hopefully 5 gen) and backup camera.
Thanks again for the input!
Jay
Guest
Posts: n/a
The ES 350 has been confirmed to have 275hp, so I am 100% certain, so will the RX 350.
We cannot say the tech in the new ES will be in the RX, since the ES is a ground up redesign and the RX is a freshning.
There are members who have said the RX 350 has ads in the new car mags, not sure if we can confirm cosmetic changes.
Rx 350
Hi All,
First I would guess that this is one of the final iderations of the current body style.
we all know the power plant is being boosted. Other than that I suspect any additional changes will be baubles and bolt ons. They need to maximize their return on the tooling, which was required to produce this current body style.
I suspect that a completely new body style is probably 1 - 2 model years away.
The RX is already stuffed with pretty much all the electronic gadgetry one needs.
Becks
Becks
The print ad. in this month's car and driver has one small shot of the front 3/4. I can't see any differences. It mentions that the new 35o will have 270hp (with a typical lawyerese footnote stating that's only achieved on 91+octane gas and using lower octane will result in lower power). Nothing else.
The RX350 is already on sale in japan as the harrier it has the 3.5 but same transmission i didnt see any changes in the styling maybe led tailights but it basically was the same exact vehicle.
Found the ad in my issue
However, next to the 270hp is an asterisk and at the bottom of the ad says
"Rating achieved using the required premium-unleaded gasoline with octane rating of 91 or higher. If premium fuel is not used, performance will decrease. 2005 Lexus"
Originally Posted by Lil4X
My RX 330 was one of the earliest models (May '03), and has experienced no real problems, although I had the transmission re-flashed to a new shift algorithm, as the original was a little rough shifting. I've experienced a power rear door failure (twice in three years), but cannot duplicate it, and now my HID headlights have started to leak. I don't believe I've had any real problems with either car - nothing that wasn't handled quickly under warranty by my dealer.
Are there disadvantages to being an "early adopter"? Despite the conventional wisdom that "you don't want to own serial number "1" of anything", the only downside I've seen is option packaging. Lexus has a habit of forcing certain options on you, and bundling certain packages.
Our 04 RX330 with a March 03 build date also had many of the same problems you have. I also got the recall for the exhaust system and had the hatch ECU replaced for the intermitent power hatch failure. My headlights now have condensation as well. I don't have too many rattles, but I do have them. I will agree that the bigest down side for 1st model year is the lack of options. That and the price. I probably will never buy a first model year again. I did that once before and said never again, but I bought the 04 RX330 anyway since it was a Lexus after all. However, 1st model issues apply to Lexus just like the rest of them. If I just wainted for the 05 I could have had more standard options, more available customized options, and all for about $5K less. Oh well.
Super Moderator
I would appreciate it if when someone gets one of these fine babies to take it to a track with about a 1/4 tank of gas and let me know the real 1/4 mile time, not the Lexus times.
Here is a link from the other section of this board for the 330 and 400. It lists the Ukrainian Lexus site and I threw in a translation website towards the bottom. You can also use that translation on the Japan Toyota Harrier website.
https://www.clublexus.com/forums/sho...d.php?t=198374
Check it out. I thought that was pretty cool!
Jay
Probable RX350 Power
Toyota has made no secret that the '07 Camry will have a 350 engine and 6 speed automatic. The hp numbers they use (268) is the same as the current Avalon engine, so it is likely that the RX350 (and ES350) will have a version of that powertrain. Exact horsepower will depend on things like exhaust restriction, ignition advance curve, intake restriction, etc. Even so, the 350 engine with a 5 speed auto gets the Avalon to 60 in around 6.7 sec depending on whose test numbers you believe. With the 6 speed transmission the RX350 could be in the 7 second range to 60, or about as fast as the RX400h.
Steve
2006 RX400h
2003 G35 Coupe
Steve
2006 RX400h
2003 G35 Coupe
I saw Car and Driver magazine, so the RX350 remain similar RX330, but main new were 270HP and 10 HP less than Infiniti FX35! Starting price around est. $39000-$40000. Good new for Lexus RX fans out there! Maybe, New 2007 X5 remain 255 HP use same engines as 3 & 5.
rx350 info
so chicago auto show comming arround. ive seen first hand the car. knoticable difference. obvously the motor. gs motor and front bumper when i get home ill upload the pix. just wanted to share the info with everyone
Now please someone tell me that I am wrong. Even IS350 has the more powerful 2GR-FSE AND it is 500lbs lighter.
Super Moderator
