engine question
Hi gys ,this morning i stepped in my rx330 i noticed that the rear door closed automatically then i tried to start the engine it made some noise like hishing then run normal,do you think that the battery was drained because of the the door was not closed and that noise is normal. thanks
No don't think the battery was drained at all. If you could start the car the battery was fine. Also, if you leave the doors or hatch open for a set amount of time (I believe it was 5 minutes or so) without further closing or opening any other door, the interior lights will turn themselves off. By you leaving the hatch door open all night meant nothing aside from it being open. All the interior lights would have turned off.
kishy
06-19-20 11:09 AM
