Air Suspension
My 04 RX makes a clicking noise when the air suspension is in operation. I noticed it when I tried to lower the car while on freeway. Also, my car has "Quick Access" mode where the car drops ~1" when put in PARK for easy access, I could hear the clicking noise that lasts no more than a minute. Has anyone with air suspension have the same experience? Should I take to dealer's attention? Thanks once again guys!!!
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Originally Posted by Nostics_RX
My 04 RX makes a clicking noise when the air suspension is in operation. I noticed it when I tried to lower the car while on freeway. Also, my car has "Quick Access" mode where the car drops ~1" when put in PARK for easy access, I could hear the clicking noise that lasts no more than a minute. Has anyone with air suspension have the same experience? Should I take to dealer's attention? Thanks once again guys!!! ![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
1. use both ur hands. stick your index finger in your ear.
2. if the noise is still there push the index fingers even deeper in ur ears.
3. if you still hear the noise... move away from your rx appx. 30 ft.
if all else fails... sell it n get a new rx. good luck.
Thanks. I am merely asking folks with air suspension if it is normal. If you read carefully, nowhere did I mention it being annoying. I love my RX as much as you do. Thanks for taking time to reply!!
Originally Posted by ph_RX330
the clicking noise does not hurt you.... dont worry about it. if the clicking noise bothers u soooooo much... then i have some instructions that may help....
Ill go check mine later.....I cant recall clicking but the air pump doing its thing, it does make a little noise while operating!
i have air suspension on my 04 rx,it makes those clicking noises and sounds like air compressor which lasts short time untill the hight settled,i think this is normal operation.if you notice any new changes ask the dealer.
Thanks very much guys for sharing the info. I just needed a little confirmation that the faint clicking noise is experienced by other RX owner with PP. Thanks shikbas and booyah!!
Originally Posted by Booyah
Much help there you freakin JackAssss!
no one responded .... so at least it got the topic going. plus it wasn't in response to you... just giving a suggestion... weather u like it or not is your opinion. mind your own business! Nostics_RX i meant no disrespect... just a joke.
bpfl
anytime *****!
bpfl
bpfl
