Rear Axle Lube Change
Want to change the rear axle lube on our '04 RX. It has a drain plug & fill one also. Problem is that there is not much room to get the qt. of synthetic GL in. If I could I would put a hose on the end of the plastic qt. bottle & sqeeze it in but there does not seem to be room to get the bottle up there.
ANY IDEAS HOW ???
ANY IDEAS HOW ???
ANY IDEAS HOW ???
ANY IDEAS HOW ???
Got the suction gun & got extra hose too, about 2 ft.
Time to go to work & open the drain up. Any idea as to what size the drain pluf is??
Book states it holds 1 qt. Think I'll do the transfer case too.
Super Moderator
The long hose method was the only way I could do the rear differential on my RX300.
The transfer case needs the fluid slightly more than the rear, but do both.
Took about 1/2 hr. to drain, flush out & refill. Boy was the old lube dirty & the plug was full of black gunk.
Next stop is the front transfer case. Then a compplete flush of the auto tranny.
Putting Amsoil synthetics in everything.
PS - the rear plugs came out with a 3/8" allen wrench.
Super Moderator
ANY IDEAS HOW ???
ANY IDEAS HOW ???
We have 50K on it. I should have changed the gear lubes sooner but thought it was a bigger job then it was. I like to do things like this myself whenever possible. Hard to get someone to put in my Amsoil anyways as it would be like going to a restaurant with my own steak & asking them to make it.
For the price of a few qts. of synthetic gear lube & as dirty as the old stuff was it was time, past time as far as I am concerned.
Next job will be flushing the old tranny fluid out and putting in 10 qts. of new synthetic. I will take that to a small garage near here as they have the transmission flusher made for this job.
Oil Change Interval depends on usage. For RX300, it is heavily front biased, the gear oil in front differential take more beating than the rear ones. Here is a used oil analysis on a rear wheel drive Toyota Tundra's rear differential. The owner goes off road a lot. 20K the Mobil 1 75w90, which is synthetic oil, needed to be changed.
http://www.ezdries.net/Vidpics/temp/...ff%20share.pdf
I feel comfortable to change the rear differential on my AWD RX300 every 60K, front one around 30K to 45K.
Would any care to recommend a good service manual for the '04 RX? Thanks. The Amsoil site shows the proper types and quantities, but a full manual with pictures for the take aparts would be nice for the mechanically challenged.
Also, as part of the diff oil change, would it not help to purchase some less expensive diff oil in addition to run through. Perhaps 1/2 qt as a flush?
Originally Posted by RX330inFL
I checked the PDF copy of the maintenance schedule I keep on my Palm and it shows 60K for the differential oil replacement. No reference prior that I could find. My '04 RX330 is FWD, though as a long time Subaru owner I understand the advantages of 4WD and AWD. Seeing the problems some where having with the RX300 on transmissions and such I may need to get more proactive on these types of servicings if I wish to hold my RX for a long time.
Mobil 1 75w90 cost ~$8 per quart, Amsoil is about the same. I would not use anything other than synthetic beause its higher flash point and better resistance to oxidation.
My RX350 manual states the auto transmission requires a special type of fluid, not Dexron 2 or 3. I did not realize Amsoil made an auto trans fluid compatible with Toyota transmission. Do you have a part number.
Steve
Steve
The RX 350 uses Toyota standard "WS" ( world standard), replaced by the dealer only. This is the next level of ATF past the Type IV. Type IV replaced Dexron III in the Toyota electronic controlled transmission.
The WS transmissions do not have a dipstick. The fluid is changed from the underside, as like a manual transmission with separate drain and fill plugs.
Steve
Steve
Supposedly, the life span on the new WS ATF is 100K miles. By the time you get close to needing a change it will be more readily available for those who want to do it themselves.
