Vaistech SLI installation instructions w/ pics for 04-07 RX
Old 03-26-13, 11:07 AM
  #136
rxdrivr
rxdrivr's Avatar
These instructions are very good, but I'll add:
On STEP #7 -- if you don't put these two bolts back, there appears to be a lot of creaking and squeaking coming from the radio unit while driving around rough roads.
The bolt size is x m6 bolt, 10mm, L16 (metric 6mm thread, 10mm bolt head (socket) size, length 16mm).
I lost these bolts, but replaced them with a $.70 replacement pack from home depot (they didn't have the exact 16mm length so I went with a slightly shorter one which seems to work).
Being prepared with these replacement bolts might be easier than trying not to lose the two while removing the unit.
Also, I went with the USA Spec PA-15 TOY ipod adapter which was a little cheaper but still has enough functionality.
Hope this helps someone.
Old 08-24-14, 10:13 AM
  #137
evident
evident's Avatar
great. i tried so hard to not lose a bolt, but sure enough i lost one. any detailed instructions on removing the center bottom plastic panel to see what's on the floor?
Old 04-03-16, 08:19 PM
  #138
JayRX
JayRX's Avatar
Default How important are those two screws for the radio
So I just added a vaistech SL3B bluetooth streaming kit to my '08 RX400h and lost both of those two bolts that are way in the back down the cavity and they are gone. The radio is still held in with two other bolts and clips so my questions is, just how important are those two pain in the a$$ screws?
Old 04-04-16, 09:41 AM
  #139
stevies30
stevies30's Avatar
I know which ones you're talking about and in my opinion they're important enough that you should try to get two more from the dealer.
dojoman
06-24-19 09:13 AM
Tim151
11-21-18 04:11 PM
86'ed
06-09-10 11:48 AM
LEXuriouss
SC- 1st Gen (1992-2000)
10-26-06 12:50 AM
flyhigh123
Performance & Maintenance
03-18-05 04:57 AM
Quick Reply: Vaistech SLI installation instructions w/ pics for 04-07 RX
