ViasTech SLX Unit In RX-350 - Fails after "AM" then "SAT1" voice command?
I have a 2007 RX-350 in which I just completed the installation of a ViasTech SLX unit . My wife and I make fairly extensive use of the voice commands for the Navigation/Radio system and discovered what appears to be a bug in the SLX unit. I would appreciate it if fellow SLX / RX-350 owners could confirm this problem.
First, verify all radio modes work through push button, ending with FM radio. Then press AM/SAT to toggle to SAT1. After it loads and starts playing, use voice command and say "AM" and the system should confirm the command and change to AM radio. After it does, say "SAT1" and wait. In my case, the navigation system repeats the command "Satellite Radio 1" but never actually switches to SAT1. Further, any attempts after this to get to SAT1, either by voice command or by push button fail. SAT1/2/3 are all locked out and can't be accessed until the system is restarted by cycling power (the car has to be turned off, not just the radio).
This problem does NOT occur on my wife's ES-330 (also equipped with an SLX unit) and appears to be limited only to the RX-350.
Can anyone else confirm this bug?
Thanks!
SonarTech
Thanks!
SonarTech
Thanks!
SonarTech
Thanks!
SonarTech
SonarTech
ps: Barring these glitches, I do very much like the ViasTech SLX unit - it work very well most of the time.
Makster
08-07-22 02:33 PM
