Thundercloud Edition Grill
#61
But I have heard it was a breeze to modify, take off and put on o the 330's...confusing....
#62
MultiTasking Mom
the only trick is the first time i tightened the new grille i think i did a few notches too tight and the rubber seal actually started to flatten out and get away from the grille, so i need to open it up again and readjust it. i don't know why i did it so tight! it's not like anyone can steal it without opening the hood
#63
MultiTasking Mom
Looks like the 330 versus the 350 will require that you replace the rubber seal that goes underneath the grille. They are different shapes. The TC matches with the 350...I suppose. Are the TC grilles supplied with the rubber seal? I would guess so.
about the 330 vs. 350. i am also pretty sure they are interchangeable. there is no question that the bodies are the same, the only doubt is whether the hole or screws on the hood changed from 330 to 350. however, given that both 330 owners and 350 owners have put the TC grilles on successfully, they appear to be interchangeable.
#64
Thanks for the info, I wanted to make sure that the rubber was part of/include on the TC grille.
#67
Super Moderator
#68
I have trying to get the wifey to buy into the TC Grille, so far no luck! I showed her the pics and she says, I like the original...the horizontal slats are like for cars........makes sense...have to tell you sometimes they make sense....ooppssss.
#69
MultiTasking Mom
at first i wasn't too keen on spending $300 on a piece of chrome plastic, but 8 wks later when i installed it, i was so happy i did. Good luck!
#70
Thanks, I needed that advice. I shall try one more time.
#73
She said that horizontal slats are common in cars..hence she is happy with the vertical ones for the RX.....I can dig it. It's her car. But I still wnat the TC grille....looks like I will have to spring for the $$.
#75
LOL. i'm a woman and i am not really into mods but the TC grille was the first thing i did to my RX. granted it's not my daily driver anymore, but i still love seeing the grille.
i would say if you are still trying to convince her, tell her that it will make it a little different than the other 1000s of RX's out there you see each and every day. at least that's what makes me happy
