Wheel Pics!
Thanks,
Kan-O-Z
The front is flush while the rear has probably at least 5mm or more to spare. This is with the drop though. If I had to do it again, I might go a little more conservative and go with a +25 if available. Also, this is with the over sized tires as well. If I used traditional 245/45/20 the front would probably be a few mm under the fender (I'm talking total with the tires mounted, as the rim itself is under the fender).
Kan-O-Z
Remember, mine is a 8.5" wide rim, so you could use a lower offset on an 8' rim and be okay. I would plug those numbers in a wheel offset calculator and compare them to my set up. The front has a lot of room. The rear has very little back spacing room so too high an offset will cause you to rub the strut, or rub the inner fender liner. My set up has zero rubbing.
Kan-O-Z
