Oil change
Oil change
I own 2006 RX-400h and was wondering if anyone knows how to reset the Master Warning Light (small red triangle mark) in the instrument cluster.
This red triangle mark shows up every 5000 miles to indicate for oil change.
I have been taking to a local dealer for oil change and they reset the indicator at the same time after completion of oil change. From now on, I want to change oil by myself but I need to be able to reset the warning light.
Your advice would be greatly appreciated.
Thanks
Thanks
Reset Oil Change Light
The instruction are typically in the manual, but, form memory, on the 330:
Make sure that your odometer is set to show miles.
Shut off ignition, While holding in the odo button turn ignition on (you do not have to start) and keep holding button till reading is 00000000.
This will not interfere with your odometer readings after the reset.
Cheers.
Cheers.
DocRock143
12-07-06 01:19 PM
Lextranny
01-18-05 01:23 PM
