Anyone Consider 2007 Acura MDX?
#46
I think the 2007 MDX is awesome. The MDX actually has more utility for us because it is bigger than the RX350, gives us the option for a 3rd row of seats that folds into the floor, and handles better than the RX350.
We are going to wait until the second model year to purchase the MDX to let them work out problems if any. I have learned my lesson by purchasing the first year ES350...lots of problems with no solutions.
#47
To couple with the newly gained additional horsepower and torque of the V6, the all-wheel drive RX 350 uses a viscous limited-slip center differential to enhance drivability in all types of driving conditions. The full-time AWD system works with TRAC to evenly distribute power to both axles with a constant 50/50 front-to-rear power split. If slippage occurs, the viscous coupling differential directs torque to the wheels with the most traction.
#49
I agree. I dont see how the SH-AWD will lose control in the snow. If anything, torque is allocated to the wheel with more traction, whether it be SH-AWD or the Lexus' AWD. The only time I can see a car going out of control is if the driver makes a bonehead move and floors the car through the turns, tires are crappy, or the road is too slippery to even drive on. In that case, it's not Lexus or Acura's drivetrain that's the problem
#50
"But not in the snow. With about 50 cm of the white stuff on my street in Delta, B.C., I was shocked to discover that the MDX could barely get out of its own way and really struggled on compacted ice and those wonderful frozen potholes and miniature gullies that build up in intersections.
The problem seems to be within the SH-AWD system, which programs the engine to re-direct power when any of the driving wheels start to slip. But it does so in a way that is meant to stabilize the vehicle during high-speed cornering, not in the middle of knee-deep snow or on an icy side-street."
#51
http://www.theglobeandmail.com/servl...cialGlobeAuto/
Once again the wrong focus for this vehicle. Handling should not be a higher priority than snow driving capability. This is why the Lexus sells so many vehicles. They really analize what the focus of a vehicle should be.
Kan-O-Z
#52
Guest
Posts: n/a
Its the gotdamn fascination with the Nurburgring (this is not a MDX rant, an ALL automaker rant). They should test SUVs in snow courses, not a damn racetrack
In 5 years, I've seen people complain more and more about
rattles
low profile tires
harsh ride
tire usage
agrresive brakes
etc
And I can't help but think it is b/c of engineers fascination to please car reviews and not people.
(rant over)
P.S- I do wish to drive the "ring" one day.
#53
This is really surprising and unfortunate. I guess I can understand why the SH-AWD can work against you in the snow. Here is my guess. When making a turn in the snow, the outer wheels are given extra power thus causing them to slip in the snow. This in turn causes the stability system to kick in and control the car by cutting power, etc...
Kan-O-Z
Kan-O-Z
Here is one RX330 owners that had wheels spin, engine shut down, and had to ask guys to push the SUV out of a deep snow
https://www.clublexus.com/forums/sho...d.php?t=204368
OT, I believe RWD SUV will do worse than AWD with snow that deep.
#54
I hasten to add that my test car was equipped with SUV-specific, all-season tires (Michelin Latitude) and maybe that was the problem.
Here is one positive comments about SH-AWD in the snow from an owner of other AWD cars.
Have had my RL for two weeks now and the drive is incredible. I'm in Montreal, Canada and we have had our share of snow and ice already and the handling is amazing. I have driven all types of AWD systems in the past (Audi, BMW, Jeep, etc.) and can easily say that this is the best yet.
#55
Rx350 does way better in the snow when one would expect (my still has stock tires on it)
But hey, MDX is a fine car, I test drove it, it will out corner RX any day and that is my only beef with the RX so far along with shallow seats. MDX has the same seat problem too though (damn Japanese guys are just too small to see a need for a deeper buckets)
#56
check out this thread, 50cm is deep snow, it is a challenge for any SUV.
http://www.canadiandriver.com/roadtest/07rx350.htm
Kan-O-Z
#57
Tuned, you are missing the point, that thread is about RX330 and not 350, 50/50 split and limited slip make a huge diff in the snow (along with the light weight)
Let me go one step further from CK6speed's comment on MDX having all season tires and try compare different test setups between RX350 and MDX
Direct quote,
Here, anti-lock brakes, vehicle stability control (VSC) and, above all, good winter tires are essential for safe foul-weather driving.
And the RX 350 has it all.
but it also speaks to the quality of the rubber under the car - in this case, Bridgestone Blizzak WS-50.
#58
Drove the MDX and it's super smooth. Price wise, it was in the ball park of the RX. The problem for me was the size. Just too big and I had no need for the third seat. Bought the RX350 and very pleased so far.
#59
The tranny is WAY smoother than my RX 330 (even after TSB applications), but I know they've improved that in the RX 350. The MDX is DEFINITELY wider, but it didn't feel longer to me (it's 3-4" longer than the RX). I was surprised to read the MDX is lower than the RX.
I just closed the deal on an MDX ... probably the main factor was that I've already had a Lexus RX 330 and I find the RX a little bland. I have enjoyed the car though! Seriously considered the RX Hybrid, but with the freshening in February (won't be applied to the 400h for the early '08s) and then the new model in April '08 (or so) I figured my car would feel a little dated (to me personally ... obviously it's still an awesome car). Plus, with as much highway miles as I put on it didn't seem to make as much sense to get the hybrid for so much more for only 3mpg improvement.
I'm picking up the MDX on Saturday ... hoping all goes well.
#60
I thought I highlighted the fact that I still have stock tires, which is same sucky Michelins all seasons tires as MDX had in the link above.
Look, I am just stating my observation here and you don't need to agree with it, sorry they don't teach that in the high school science classes, it's called Pluralism or acceptance of diversity.
