Question about phone Bluetooth connection
I have a '07 RX350. I tried to connect a second phone via bluetooth and it required me to cut the connection to the first phone. I know that you can't have both phones active with bluetooth at the same time, but I thought that you register multiple phones? What am I doing wrong?
Also, when you have multiple phones registered (if, in fact, you can), how do you select which phone will be active with the bluetooth connection if both phones are in the car at the same time?
Thanks.
Thanks.
1. Push hard button "Info"
2. Select "telephone"
3. Select "Select Telephone"
4. You should see both phones there, select the one you want.
5. Whan asked "do you want to disconnect hte first phone" answewr yes.
Something like that.
Oh...ok...I guess that I didn't realize that you had to go into that section each time you wanted to switch phones...I was under the impression that when I cut the connection it was erased, not just switched to the other phone temporarily.
I will check that out later...thanks.
