need to know how to remove headlights to replace HID bulb.
Old 02-11-07, 04:56 PM
DJ SprinklesNJO
DJ SprinklesNJO's Avatar
Default need to know how to remove headlights to replace HID bulb.
i tried a search but came up on instructions only for the rx300.
My passenger HID bulb burnt out. Id like to replace it however there is just no room to get my hand in there. so does anyone know how to remove the headlights completely from the truck. also whats a good replacement for the stock HID bulb on a 2005 rx330. thanks
Old 02-12-07, 04:42 PM
DJ SprinklesNJO
anyone?????? please need help. my truck looks like popeye with only one headlight workin.
Old 02-13-07, 12:47 PM
Orzel
Orzel's Avatar
Wish I could help, but will bump to top. Cheers
Old 02-13-07, 07:50 PM
sharpener
sharpener's Avatar
hmm, i change my bulbs a few times, but there is no need for me to remove the headlights, just twist the rubber seal, remove the metal lock, and off it goes
try to get ur hands on a pair of genuine phillips 6000k, 85122 WX (i think so abt the wx thingy)
Old 02-18-07, 04:06 PM
DJ SprinklesNJO
well good news and bad news. good news is i got the headlights off and took pics, so ill post how to do it. but bad news is.. the bulb is not burnt out. i even swapped the two and still not working so im screwed. the wiring looks fine, no cuts or tears, theres no trace of water for it to short circut. im thinking a module or something malfunctioned.
Old 02-18-07, 08:04 PM
DJ SprinklesNJO
ok first step, remove bolt from top of headlight fixture
then remove second bolt.
Old 02-18-07, 08:06 PM
DJ SprinklesNJO
then remove third bolt with is located behind the headlight. in the case for the driver side, its by the battery and fuse block
the last bolt is a little harder to get to. i actually had to remove part of the bumper, or at least pull it down enough to get to the bolt.
Old 02-18-07, 08:09 PM
DJ SprinklesNJO
this next step is to gently pry up on the plastic tab to release it from the notch. (this is the same location as in step number 2.)
then finaly gently pop out the front of the headlight from the retaining clip
Old 02-18-07, 08:12 PM
DJ SprinklesNJO
its not that hard, just be patient, and carefull not to break any of the tabs. the one suggestion i have is definitly remove the front bumper. makes it so much easier and less of a chance to scratch or damage something.
Old 02-22-07, 10:16 PM
joako
joako's Avatar
Arent HID covered by the warranty because the lights are supposed to last "forever"?
Anyone figure out how to turn off the DRLs yet?
Old 02-23-07, 12:03 AM
Carbon~IS
Carbon~IS's Avatar
If it wasn't the headlight bulb, than it might be either the fuse, or the ballast.
Cross your fingers and just hope it's the fuse because ballast are hella $$$$$
Old 02-23-07, 02:55 AM
Grumpa72
Grumpa72's Avatar
Holy Lumens, Batman! All that just to change out a bulb. Tell me it ain't so!
Since your car is an '05, shouldn't something like that be covered under warranty?
Gary
'05 330
Old 02-23-07, 04:37 PM
DJ SprinklesNJO
its not the fuse, bc i noticed one day it would work then next day it wouldnt, then next day it would work again, untill finally it stopped working totaly.
so your right its prob the ballast. = crap
yes it is prob under warranty, but ive done so much after market work to my car, my dealer tells me they dont want to mess with my truck. which i can understand. and they are extremely nice to me, so i dont mind. ohwell
Old 02-23-07, 05:25 PM
AM1
AM1's Avatar
i wonder if its just as hard to remove the rear tailights.
Old 05-27-08, 04:34 PM
BuckyB
BuckyB's Avatar
If you're only changing the bulb, you don't have to remove the headlight assembly, nor the bumper. There is a 4" grey plastic disc at the back of the headlight with a molex plug and 3 fins. Unplug the molex and turn the disc about 1/8 of a turn counter-clockwise, using the fins. Then pull out the disc. It fits in tight with an o-ring. Inside is a metal cup, about 2" in diameter. It similarly comes of with a bit of a twist. Then there are 2 spring metal clips that are pushed inward and flipped down. The bulb should just pull out at this point, or perhaps with a slight twist. DO NOT TOUCH THE GLASS PART OF THE BULB! The bulb will run you about $130 at Autozone and they'll have to special order it for you. It's a a D2S. I suggest swapping the left with the right first to see if the problem is the bulb. In my case, it wasn't, so I cancelled my order with Autozone. I'm thinking it's my ballast. I've got a used headlight assembly coming from eBay, as they're about the same $ as a ballast alone. I WILL have to drop my bumper to complete this project.
Quick Reply: need to know how to remove headlights to replace HID bulb.
