loud road noise on 350 and Michelin tires
the nittos were around 145 or so per tire. the only thing though is you have to go up to 255/55/18 i dont think they make it in 235/55/18. when i got my tires last time they were on national backorder dont know if they still are. so they might be hard to get. i know that falken, kumho, and toyo all make similar tires for suvs/light trucks
255/55 is a taller tire. 255/45 is the same ratio. Do you have the 255/55?
Do you have stock 18's? No rubbing?
there was another thread around here somewhere where the owner used the stock 18's and switched to the larger 255/55/18 tire. That person sugeested putting in spacers in the back i think to prevent rubbing. when the tires were being put in i asked them to check for rubbing. they said there wasnt any rubbing though it was a very tight fit in the back.
There was no 245/55's? Or you really wanted the wider tires...
for some weird reason all light truck/suv tires in this particular size range jump from 235-255. the guys who put my tires on said that 235/55/18 is a strange size cuz its not small like what would go on smaller suvs/trucks and its not larger like 255/55/18 which is more common and go on most other suvs/trucks this size or larger.
Can you take a pic and post please? I want to see how it looks....must be great, and no rubbing right?
There was another guy who ended up putting the Alenza's and it is 255/55's too. I guess no issues.
I can not seem to find a local supplier for the Alenza....what tire place have you purchased these from, anybody?
I almost forgot. I have not ordered from them, who normally installs the tires for them?
