how to install aftremarket radio
hey guys,i need help on installing aftermarket radio.what do i need?will the metra 70-8113 work.how can i bypass the factory amp if my car haveone.! have a 04 lexus rx330 without navi system,it's just a plan factory system
plezzze somebody help me
I don't think there is a wire harness adapter for the RX yet, but it is pretty simple as all you need to do is tap the ignition wire, constant 12V and you are pretty much in business. For the amp remote turn on wire if you need it just run your own to your after market amp. There is no power antenna in the RX so you don't need that wire.
I can only speak for the NON ML amp since that is what my RX is. It is easy to bypass the amp. Just remove the molex plugs from the amps output and tap the correct wires to each speaker. I don't have wire color codes with me since I did mine a couple of years ago, but it is no big deal. I got the wire color code from the online service manual website and just searched for the correct wires until I found them all. Then I just tap into them and soldered my own wires to it. In this case you can use your own amp which I did, or use the head units power amp.
Where can we buy this kit? And is it the one seen on these pages?
http://www.cardomain.com/ride/2491254/2
http://www.cardomain.com/ride/2413004
Thanks!
Thanks!
Thanks!
Thanks!
Lexicon1
SC- 1st Gen (1992-2000)
12-12-10 08:53 AM
