Replacing the OEM battery in the RX330
Old 02-28-09, 06:04 AM
  #46
eisens
eisens's Avatar
Originally Posted by cdnewton
I had to reprogram the power windows and the sunroof. Strangely enough, I didn't have to redo the radio settings, not sure exactly why.
Hope this isn't answered somewhere -- but I searched and searched the forum. . .
My battery died and Sam's Club installed a nice new one (2004 RX330). Seems like the clock and radio are fine (I have GPS), but my windows operate from each door, but not from the driver panel.
I'm assuming I need to reprogram the windows -- but HOW?
I see lots of posts about having to do it, but none on HOW to do it.
Thanks.
Old 02-28-09, 07:50 AM
  #47
salimshah
salimshah's Avatar
Received 1,055 Likes on 952 Posts
Thanks.
I am baffled. The reprogram is to make the pinch protection reset. So by holding the switch you are training the motor to keep applying force to move the glass. Once it learns the force needed to move without any extra resistance, then a single flick will make it travel all the way.
The re-learning/programming is needed if the windows do not travel all the way up on a single flick of the switch.
Back to your problem ... the driver has a the master switch to disable the rear switches ... The rear switches should not be able to over-ride. It seems the driver switch may have gone bad [coincidence with battery change].
Salim
Old 02-28-09, 10:59 AM
  #48
eisens
eisens's Avatar
I was afraid of that and hope it isn't that!
I have a kid and dog so I usually keep the safety button "down" to lock the other three windows, but now even with it "up" the windows won't open from the driver's side.
This along with the two keys that broke in half in the same week make my Lexus oh so much fun right now!
Does anyone else think I have a bad switch or is there something I can try to "reprogram" it?
Old 02-28-09, 11:13 AM
  #49
salimshah
salimshah's Avatar
If the switch is the problem ... the more bad news will be that Lexus sells the whole set and it might run 500+ more like 800. Testing the switch is not difficult and if you dig you can find instructions to pop the panel out.
If you prefer, you can start an other thread (it really does not sound like a battery problem)
Salim
Old 02-28-09, 11:19 AM
  #50
eisens
eisens's Avatar
Old 04-18-09, 02:34 PM
  #51
Frankr66
Frankr66's Avatar
did you ever figure out what the problem was and have it resolved?
Old 06-01-09, 06:32 AM
  #52
daryll40
daryll40's Avatar
What happens if you DON'T reprogram the windows?
Old 06-01-09, 06:35 AM
  #53
tfischer
tfischer's Avatar
They will work, but the "auto up" and "auto down" don't work correctly (because the computer lost track of where they were when the juice was cut off), so you will be reduced to holding the window button in the "down" position for the entire length of time is takes the window to retract into the door.
Most of us can't live like that.
(Remember window cranks - no wonder our arms used to be so strong.)
Old 06-01-09, 06:45 AM
  #54
daryll40
daryll40's Avatar
Thanks for that info.
Don't forget VENT windows. Great cheap "A/C" back when real A/C was a luxury option only.
Old 06-01-09, 07:10 AM
  #55
tfischer
tfischer's Avatar
I loved the vent windows.
My rich uncle (literally) had a Cadillac in the late 50s or 60s with power vent windows - now that's luxury.
Old 06-01-09, 02:40 PM
  #56
daryll40
daryll40's Avatar
Yeah but if he was REALLY rich he would have had "underdash" A/C installed too!
Old 06-11-09, 06:31 PM
  #57
joako
joako's Avatar
Originally Posted by catdaddylo
Interstate makes batteries for a lot of foreign automobiles. The OEM Lexus battery is made by Interstate is what I was told by a Lexus mechanic.
My OEM battery was made by Johnson Controls and I replaced it with a Johnson Controls from WalMart. Replaced because every few days I would have to jump-start the car.
The battery was about $75 vs the "auto parts" places wanted about $110 for it. Even then, that is overpriced for such a tiny battery. The one for my BMW which is about double the size was $65.00 @ Walmart. 3 year replacement warranty which is about the same as the other places.
Old 06-11-09, 06:38 PM
  #58
mandyfig
mandyfig's Avatar
So the battery replacement took care of the problem?
Old 06-13-09, 06:26 AM
  #59
tromly
tromly's Avatar
Originally Posted by lex_rx
Curious to know if lots more people in the eastern part of the continent change their batteries every 3-4 years as mentioned. Before the 04 RX330, I never replaced the battery on my 98 Sienna. I had the van until trading it for the RX last year. Personally, I don't like batteries, like in RX, that you can't open and refill the distilled water.
I have two 04's, I replace the batteries every four years, use Interstate, about $75 each. Never had a problem with Interstate or Duralast. Just part of my regular PM, every four years, I never wait until it gets weak or gives out.
Old 06-13-09, 09:08 AM
  #60
daryll40
daryll40's Avatar
I have sort of concluded that this is a good idea. If they last 4 years, it's time.
Quick Reply: Replacing the OEM battery in the RX330
