tires pressure light never came on
i have 05 rx330 and the tires pressure light never came on even when one of the tire was at 15 psi. i cant depend on the system anymore because when i check the pressure they're usually really low. do you guys think something wrong with the system?
(do they have a sensor in the wheel or do they go by the abs speed sensor?)
If they are indirect (ABS based), then you can't expect it to know a tire is low unless you are traveling at a certain speed... now, if it's direct (meaning they each have a sensor) then there is no excuse... I usually find them to be quite accurate...
are the 05's direct or indirect based - I don't recall
indirect - abs speed sensor calculates difference in wheel speed, and looks at a reference when the system was calibrated...
20mph is typically the minimum for them to operate...
indirect does not have sensor in the tire transmitting pressure to the computer. it calculates, based on wheel speed, and frequency it one wheel is different than the rest, sooo if all for tires are flat=no light on dash, if all four tires are close ie. 20,24,25,26=no light on dash, aswell bumpy roads, bad wheel bearings, mismatched tires can trigger a false light on dash.
Direct type actually sends a pressure to the computer so it really knows specifically what the pressure is.
I have the 400H but I am guessing it uses the same system as your car. I got the car a while ago but I have just gotten around to reading the book. I recall reading something about filling all the tires with the correct cold pressure and then you need to do something to calibrate the system. I don't have my book handy but I am wondering if you did the calibration thing?
ok brought the vehicle to the dealer today and was told everything is normal, so i ask for manager and we let the air out one of the tire to 15psi and drive but no lights came on. dealer called around and asked but no ones really knew what was wrong with it. they reset the program and told me to drive at a constant speed for 20 mins for the program to memory something. I tested it at 15psi after an hour drove home from the dealer but no luck. what should i do now?
Take it back to the dealer . . . for some reason either the tire pressure computer is not triggering the low tire light, or the computer is not receiving data from the sensors. Your dealer should either be able to trace this, or at least replace components until correct performance is observed.
As to the dealer, take it back as many times as you need to in order to get the problem fixed. If necessary, elevate the issue to Lexus USA and see how long it takes the dealership to fix the problem. Or, drop the car off with them, ask for a loaner and then have them call you when your car is fixed. I suspect that it won't take long that way.
I thought it was brilliant to let the air out of the tire to 15 psi and then put the tech in the car. Can't argue with that or say "we can't duplicate the problem."
Gary
'05 330
correction, they earn $30-$40 per BOOK hour... which means if it takes them an hour to do a 3 hour job, they just made $90- $120 in one hour alone...
But then again, the consumer would never know the actual time it took, right?
