K @ N Filter
Old 05-12-07, 10:17 AM
Lexmex
Super Moderator
Lexmex's Avatar
Originally Posted by Radekn
K N Cold air intake
Are you talking about the filter or some kit, as I am not aware (short of something customized) that K&N makes any kind of CAI system for the RXs, and most of their stuff is ram air.
Old 05-12-07, 05:41 PM
Grumpa72
Grumpa72's Avatar
Will i get a better fuel mileage and how much ???
In the classic car and muscle car world, there was a thread on this where mileage was discussed and K & N filters came up. To give the reader's digest version - "there ain't no free lunch". One of the ways to improve mileage is to improve breathing which means a freer flowing air filter. The gist of the discussion was that K & N gives a freer flowing air filter by allowing more particulate matter through their filtering medium. So, you MAY get a mile or two better fuel economy but probably at the expense of increased internal engine wear.
Just my opinion.
Gary
Old 05-12-07, 11:02 PM
AM1
AM1's Avatar
you realize that you can always remove the stock air box then put a round type filter on the end and leave everything else including the stock hose and connectors the same. my mechanic said that just repalceing the filter should not be a reason for a dealer to refuse to work on your car.
Old 05-13-07, 06:02 PM
mandyfig
mandyfig's Avatar
Gary is right. The net free area determines volume of air. K N allows more air, less media...is it allowing particulates to go through....maybe debatable...but concept is right.
Old 05-13-07, 07:52 PM
Todd
Todd's Avatar
Default Not really and danger of
the oil from the filter contaminating the MAF sensor. This has been reported as a problem on a BMW forum I frequent. Plus as I have pointed out before unless you install some sort of better exhaust system you can not flow more air effectively if it has no where to go. So, how about a cold air intake AND a set of headers and dual exhaust the whole way back. Unfortunately, I have never seen a performance exhaust or cold air intake for the RX. Anyone else?
Old 05-14-07, 06:53 PM
mandyfig
mandyfig's Avatar
Todd has a valid point...CAI alone will not add HP, you will maybe like the sound....but Lexus is trying to absorb the noise.....
Old 05-15-07, 06:25 AM
The G Man
The G Man's Avatar
There have been a few independent studies on aftermarket filters and found them all to filter less effectively. In addition, they tend to clog up faster than paper filter.
Old 05-15-07, 08:50 AM
mandyfig
mandyfig's Avatar
Also the re-charge kit is expensive....I have always stuck with paper filters...
Old 05-15-07, 10:29 AM
The G Man
The G Man's Avatar
I use to use K&N filters, but recently switch to TRD filters. I just replace them every 2 years. They cost twice as much as the OEM paper filter, so its a wash price wise.
Old 05-15-07, 02:34 PM
mandyfig
mandyfig's Avatar
Where do you purchase the TRD filters?
Old 05-16-07, 06:22 AM
The G Man
The G Man's Avatar
I bought it from Sewell, but its for my other car. I didnt see one there for the RX.
Old 05-16-07, 10:11 PM
AM1
AM1's Avatar
the trd filter is like a foam type thing right? if so i'd use an HKS one.
Old 05-17-07, 06:12 AM
The G Man
The G Man's Avatar
No, TRD is the same as K&N. The material is very similar and needs to be oil. The dimension and the plastic housing is diff.
Old 05-17-07, 07:19 AM
mandyfig
mandyfig's Avatar
The oil compensates for the lesser media....in effect, filtering the same but allowing more flow....
gypsyboots
Maintenance
06-27-18 11:47 AM
funcrusher
08-17-11 04:11 PM
hlu1
IS - 1st Gen (2001-2005)
07-21-10 02:34 PM
mlevinedc
RX - 1st Gen (1999-2003)
06-29-01 12:56 AM
mrKophee
SC- 1st Gen (1992-2000)
06-07-01 02:27 AM
Quick Reply: K @ N Filter
