Water inside headlamp assembly?
Old 07-16-07, 02:21 PM
rayraySC
rayraySC's Avatar
flintRX04,
Where did you get the headlight assembly...from the local service department?
Where is the 3rd screw to remove the headlight assembly? Do I have to remove the front bumper?
Any instructions you have will be very helpful...thanks
Old 07-17-07, 08:14 AM
flintRX04
flintRX04's Avatar
RayraySC,
Yes I picked up the assembly for the local service department.
The third screw is right next to the side of the bumper. Its best to remove the screws that hold the side of the bumper from which you are trying to remove the headlight (there is also a tab next to the headlight and in front of the grill you will need to remove). You do not have to remove the bumper entirely. Once you remove the third screw located on the side next to the bumper wall, pull the bumper partially off to remove the headlight assembly. You need to do this because there is a clip that rides underneath the bumper to keep it in place. Good luck!
Old 08-01-07, 08:58 AM
Dinomon
Dinomon's Avatar
I also took my RX330 to dealership for headlamp moisture and they said it is normal and refusing to replace them. What should I do?
Old 08-01-07, 09:30 AM
The G Man
The G Man's Avatar
Call the Lexus 1-800 number, they can ask the dealer to replace it, and no, its not normal.
Old 08-28-07, 10:13 AM
LBCDan
LBCDan's Avatar
I noticed I had moisture in both headlamps after I went through a high pressure car wash. By the time I took it to the dealer, one of the headlamps had dried out. The service guy told me that condensation was normal so they replaced only the one that had condensation in it. I haven't had a problem since and have never gone back to that car wash.
Old 02-24-08, 11:10 AM
mandyfig
mandyfig's Avatar
Condensation has not returned?
ryssby
Hybrid Technology
01-29-16 05:23 PM
2013lgs350
10-06-14 10:30 PM
smcleod
02-13-12 01:02 PM
Dinomon
07-16-08 11:31 AM
satxrx
RX - 1st Gen (1999-2003)
08-15-05 08:04 AM
Quick Reply: Water inside headlamp assembly?
