Water inside headlamp assembly?
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
So, I'm washing my RX today and noticed afterwards that the right headlamp assembly was "fogged up" (moisture/condensation build-up) under the glass housing. It was like a bathroom mirror after taking a hot shower.
I've never seen this before, so I assume this is not normal? The lights still work, but now I'm concerned about corrosion on the electrical contacts, etc.
It's all under warranty, so I guess I should take it in, eh?
Out of Warranty
Well known problem of long standing on the RX and SC. Should be replaced in warranty. Many, many, other accounts of this - use advanced search function to look for headlight, condensation in the RX forums.
I have been watching out for my headlights, too. Better find out before the warranty expires.
I notice that if you shoot water (a lot of pressure) onto the front quarter panel toward the headlights, that's when it leaks in. I try to shoot the headlights head-on, direct from the front of the car, if not with very little pressure from the side.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Don't count on them to change them out after warranty or even within warranty. My guess is because so many Lexus cars are affected by condenssation in the headlights (RX, GS, SC) that some dealers are just telling customers that it is normal and refusing to replace them.
If that doesn't work, then the regional office would need to be notified, I'm thinking.
Don't worry, eventually both side will have condensation
Don't get me wrong. I fully expect and believe Lexus should replace these lights under warranty. However, just look at the past problems some CL members had getting them replace at their local dealerships on other sub forums like the GS forum and such. If you have a dealership that will replace them great. Fortunately mine was one of them. If you have one that doesn't want to do it, you will have to fight for it and that makes life hearder.
So far, only my 99 LS hasn't seen any condensation. Every other Lexus I had in the past developed some sort of moisture though.
PS. Some of the latest postings I've been reading is some dealers are saying if the condensations clears within 5 minutes after the lights are turned on, they consider that normal and will not replace it. If moisture is still there after 5 minutes, they will replace it.
There should have been a TSB on this one. But we all know they are expensive. Whoever makes them for Lexus should be on the suspended list by now. Headlights are quite tricky to mold!
Keep it within the warranty period, cleaner that way. So, pay attention, or simulate the condensation.
I experienced water codensation in my driver side headlight assembly and was ready to take it to the dealer for warranty. But under closer examination I had a small crack on the top (must have been from a rock). The dealer will not replace it due to damage similar to getting a flat tire from running over a nail. So I went out and got a new headlamp assembly and swamped it out. Man it was a pain in the but without instructions but I got it done and it looks and performs like new. This included swamping out the HID ballast and other bulbs. Make sure you get the right headlamp cause there are a bunch of different ones, i.e. HID, non-HID, AFS, non-AFS, and self leveling. If your not sure just provide them with your VIN# to make sure you are getting the right one. Let me know if anyone needs any helping removing their headlight and I will try to provide you some detailed directions. Most of the instructions on the web were not very helpful or did not fully explain how to remove certain pieces.
