Breather bolt pains
Breather bolt pains
I like to do my own maintenance work on my cars. I have a 2005 RX330 and last weekend I tried to replace the air filter. The replacement I bought which was a Fram brand was difficult to push in and seat properly. It seemed to be a little too thick around the edge and it is difficult to replace the cover. In trying to force it to close, I ended up stripping the little bolt on the front side. Now I am unsure of what to do. The bolt looks too tricky to take off completely in order to replace. Am I the first one to encounter this problem and what is the best way to deal with it?
Cheer!
Cheer!
Hence, the OEM filter is better for use. The aftermarket can be a tad bigger. I had the same issue, when I replaced mine. It is a beatch to get the halves to close in. After some practice, and some bruises, you'll get used to it. Sorry that you had to strip a bolt. Use OEM filter next time. We have good OEM Lexus vendors here who sell the OEM filters cheaper than the crappy FRAM.
YODAONE
17
09-23-20 05:56 AM
sel1005
09-07-15 02:37 PM
