Question about Switching to Synthetic Oil
#31
Super Moderator
Yes.
5W40 would be fine for the 2nd gen RXs, though I would say a 0W40 for an RX300 (due to narrower cooling passages). Again, other people have differing opinions, and additives are also perfectly fine. As mentioned above, I do know of people who do use Marvel Mystery Oil, Restore Oil Additive, Auto-RX, etc. and they have also done the job for people.
I apply the same kind of idea with higher weight oil with my transfer case that has been leaking on and off for a long time, but recently stopped. I added some of BMW's synthetic 75W140 to the mix of the Royal Purple Max Gear 75W90 that I use and that stopped the leak dead cold.
#32
With only 26K, you shouldn't experience any issues switching to synthetic, especially if you have had maintained the vehicle with regular oil changes.
#33
I brought my car in to have my A/C unit fixed and metioned the leak to the service advisor he said the leak is part of the A/C unit condensation. I mentioned that I do my own oil change.....he said maybe you forgot to tighten the oil pan bolt. No way i said!!....It's coming from the seal gasket. He kept his mouth shout!
I'm due for an oil change soon. I will check underneath when I do my own oil change and take pictures. I will post it here.
#34
i have a question, does the rx330 use regular oil? or does it require synthetic or semi synthetic?
i went to EZ lube earlier and they told me that it needs a synthetic oil.
im not sure
im not sure
#37
Synthetic is worth the investment. Soon prices will be better. A lot of people are finding the value in it.
#38
Super Moderator
Engines that are switched early (like yours could be) rarely, if ever leak from synthetic. It's the ones that are switched at high mileage that have problems.
#39
Great! I am definitely going syn...500 more miles....
