Can you fill us in on the mod you are doing? Is this a cover for the mirrors or is it a complete relacement? Any recommendations or insight you wish to share?
It is a complete replacement,it came with wiring harness, you have to remove existing mirrors and run a wiring harness through from the right hand side dash to the LH side dash and connect it to the LH mirror and finally run the wire to flasher. It could take atleast 3 hours to install, my friend got it for me recently from japan.
hey sama i'm looking for a decent led flasher kit too, what brand you using? where did you get it? thanks for your reply..
I have yet to buy and since there are LED's in the mirror the suggestion was to use a electronic flasher to avoid hyperflashing(Lights flashing too fast )and causing the computer to report a bulb has burnt out and this also avoids the need have load resistors
Will call CL vendors to get the part# and see if they have this type of part in stock, otherwise will try it on the web
