Front Brake Vibration
#31
At 26K, the dealer applied the TSB and replaced the rotors, but put the old pads back on (against me asking for new pads). This was under warranty.
At 52K, the dealer turned rotors at a "reduced cost".
At 62K, a shop that specializes in Toyota/Lexus put on new OEM rotors/pads.
At 74K, that same shop turned the rotors, at a reduced cost for labor.
I wrote to Lexus and they said, sorry you are having problems with the rotors warping, but you are out of warranty.
Since we now have 85K on the RX, I am waiting for the next rotor warping to occur any day. I hope the brakeplanet or brembo rotors will help.
#32
I have 48K on my car and when I went to the dealer at around 42K they said that they applied all of the TSBs. But still the rotors were warped. I bought a certified preowned that has the warrantee until 100K. Should I take it back to the dealer and tell them the rotors are warped and they should fix it under the TSB?
I was also thinking that if they dont do it then just buy Brembos and not deal with this annoying problem every ~25K.
Thanks.
#33
I have 27k on my 04 and will come in and complain about the vibration...my pads are close to being used up. I am pretty sure the TSB has not been done on my unit. We'll see what happens.
#34
That sucks man...
Thanks.
Thanks.
I would take it back for sure, but I am not sure the rotors will be covered under the extended warranty, they should be good under the original warranty; either way, it is definitely worth a shot. Because from experience, you will see the problem again.
From all of you that have experienced the rotor warping issue, I would LOVE to hear if Brembo or whatever (i.e. other than OEM parts) fixed it, because I am pretty much fed up.
I do have to add, the rest of the car (at 85K) is absolutely SOLID, so go figure.
#35
#36
#38
Any one used Brake planet rotors on their rX?
http://stores.brakeplanet.com/Items/...6?sck=90563088
I know jfelbab has used them on his MR2 but I would just like feedback about brakeplanet rotors and brakepads from RX330/350 users.
Thanks.
Thanks.
#39
it's very likely the rotors are not the source of the problem. Perhaps it's the pad that is leaving residue on the rotor causing the warping sensation. Look into another pad such as Akebono ceramic and replace the rotors with brembo blanks.
Also, get your calipers checked, maybe they are sticking, in turn warping the rotors.
#40
Guys has anybody done the DIY on the pad replacement for our RX330-350's? Thanks in advance. I am scheduled to do this on my 30K. I am down to 2 mm on my pads, need to do it!
#41
I had 2000 RX300 and didn’t have brake problem, but that was my wife’s ride (she is not aggressive driver).
From my brake issues experienced on my Acuras and from other Acura owners’ experience, OEM brake components are the best for normal driving condition in our vehicles.
I am not talking about drag racing, etc. Anyone who believes that Lexus (or any other manufacturer) would put inferior brake components in their cars is not in the right mind. Car manufacturers go through very extensive parts design and selection, especially brake components. No car manufacturer ever wants to end up with lawsuit on their hands, and do not want to deal with brake issues free to car owner during warranty period.
Our car rotors can be turned as long as the width of the rotor is above “reject size”. That size is unique to each rotor type/model and is marked on each rotor.
Somebody mentioned here that with turning rotors loose their ability to dissipate heat from brakes. Absolutely true. Imagine that all car kinetic energy turns to heat during braking. That’s a lot of energy to absorb. However, if you have normal driving style, you should not have that warping problem, unless it is provoked by something else. For example, washing your car right after long stop-n-go driving will for sure warp rotors. Also, brakes are cooled by oncoming air during driving. If your car has underbody cladding damaged (it is usually designed to funnel upcoming air to some car components), or you install lower body kit that deflects air, you will have problem with rotors sooner or later.
#42
-- Andrey
#43
Ok, I have done my Camry many times and actually think they will be similar. Might as well do a DIY when I do it for those who are on the fence on being a pseudo DIY. Sometimes the best way to love your car is to actually work on it.
I am also familiar with Honda-Acura.
cquence
Club Lexus Vendor Marketplace
21
10-30-15 10:30 AM
