Black sandy build-up under oil cap
Please help me confirm my worry. I bought a 2004 certified Lexus RX 330 less than a month ago and opening the oil cap today I saw a thick black oily build-up inside the cylinder head?.Taking the oil cap ,you'll see it inside. I touch the stuff and some would come off like sand saturated with oil. What is this crap?.Is this what you call carbon build-up?.It only has 36000 mi. on it.
1) Could you post a picture to confirm whether it is sludge
2) If it is sludge, ask dealer to pull the valve cover for inspection.
3) Auto-RX can slowly disolves sludge and deposit them into oil filter, but since you are CPO, try 2) if 1) is confirmed
Does your engine ping? Thats a sure sign of severe carbon build up on the cylinder head. If it is a mild case then chemical treatment can get rid of it. If it is a severe case, you will need to remove the cylinder and scrape it off. Ask the dealer for their opinion.
cylinder head ..> inside the cylinder (one has to open up cylinder head after removing the valve train).
Valve cover ..> is the thing that the oil filler cap i screwed in.
Correct me if I am wrong ... you are seeing oil lumped up ... gell like as you peer through the oil cap hole.
Salim
![Slap](https://www.clublexus.com/forums/images/smilies/slap.gif)
Your post has caused a bit of confusion ..
Salim
Salim
I brought the car to the dealership this morning. Tech removed the valve cover and found that the inside is perfectly clean and I'm told that the black sandy build-up I saw when I removed the oil cap was just a coating and that that was just how the car was designed.What keeps me from being convinced is that when I touch the stuff, some of it would come off like grit. has anyone have an '04 330 with something like this?. When you remove your oil cap do you see any black sandy stuff in there or it just look clean?. and I mean if you look iside where the oil cap is, do you just see clean metal?
If you are talking right inside the oil cap, we have the film on our RX330 and have since purchased new.
I would suggest asking for second or third opinion at Toyota/Lexus, and other dealerships.
Does anyone have any details on that law suit, and which VIns are affected?
yeah I see this all the time, dont worry about sludge. when you start your car and you see smoke in the tail pipes for a few minutes then goes away, thats when you should start worrying about sludge.
