3M Filtrete filters $14.95
Hi,
Found this on FW, 3M is having a sale on cabin filters. The filters are usually $24.95 but right now with the coupon, they are $14.95 each. Shipping is a flat $4.95 regardless of how many you order. There is a limit of 5 filters at a discount per order.
http://www.filtretecarfilter.com/Step1.aspx
Coupon code is CAC3Q
The discount doesn't show until after you give your credit card info, it shows in the summary before you confirm your order, so don't worry.
Choose the filter for a 2006 Camry, it's the same as the 07 and 08 RX350, not sure about the RX's before but easily checked at any website that sells filters.
Alex
Alex
Thanks!! Ken's_RX for confirming!!
I received the three that I ordered today, each one packaged and shipped separately, just as moolman said. I also received three Scotch Brite Glass Cleaning Cloths, three detailing cloths and three Lint Rollers. Ken'sRX is correct they fit perfectly and appear to be of excellent quality.
This gets even interesting:
Join the Clean Air Club pledge Here
An Exclusive Offer for Filtrete™ Clean Air Club Members.
You will get access to the rebate form
Buy four Filtrete air cleaning filters and receive a rebate equal to the value of one filter.
Send the rebate form along with the original “Proof of Purchase” seals from four (4) Filtrete air cleaning filter packages and your original dated cash
register receipts for each filter to the address below. Cash register receipts must be dated after 6/21/07 and within a 12-month period.
I think the Clean Air Club applies only to air filters that are used in the home, like furnace filters. The pledge is to change your filters each season. Also the cabin filter has no "proof of purchase" on it.
The Proof of Purchase is NOT the UPC bar code on the filter itself. It is not a UPC at all. It's in the corner of the packaging and says 3M in red and in a box that says Proof of Purchase. Does your airfilter show that?
The three cabin filters I received from 3M have NO Proof of Purchase anywhere on the package. They also have NO UPC bar code. I do use 3M Filtrete Electrostatic Furnace Filters in my home and they DO have both UPC Codes and "Proof of Purchase" seals.
The past two times I've replaced my Toyota cabin filters they were made of some sort of nylon fiber. The paper filters were replaced by these newer nylon fiber types some time ago. Without knowing the size of particles the filters will trap I'm not sure how one can determine which is better or worse at filtering small particles such as pollen.
moolman, I would also give the 3M cabin filters a try if I found one that would fit my RX or GS. Compared to the $25 Toyota charges for a new filter, this is a bargain.
Anyone determine a 3M filter for the RX330 or GS300?
I found the best way to figure out if the filter fits is to go to the bosch or purolator websites, so a search for one of the cars that you know fit the filter and do a search for your car. If the filter model number comes out the same, you have a match. I think someone mentioned though that the RX330 uses an exclusive filter. Starting with the 07RX350, toyota got smart and just went with the generic filter size that fits a lot of the new toyotas.
Hey, I know my filters, I have a IQAir and a Friedrich C90B at home.
Below is the information marked on the 3M Automotive Cabin Air Filters. Although not marked as such, we know that this filter works with the 2007-2008 Lexus RX350:
Filter Size: P214x214x18
2002-2006 Toyota Camry
2004-2006 Toyota Solara
2004-2006 Sienna
2004-2006 Toyota Prius
2003-2006 Toyota 4Runner
2007 Toyota FJ Cruiser
2004-2006 Sienna
I ordered a lot of these filters because both my cars use it. I like changing it every 10K. I think the recommended is 20-25K but look at the filter after 10K and I think you'll agree with me 10K is a good interval. At 10K you find dead bugs, leaves and the fitler is already black. At 20K if you didn't change it, the filter is destroyed. This isn't HEPA filtering but I rather pay a couple of extra bucks to filter something out. And give the filter a good shake down and tap off all the crap it catches at around 5K. Even at 10K, I don't think I'm being conservative, just look at your filter at 10K and you can decide if you want it in there for another 5-10K, breathing that stuff in. ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
During its service life—averaging 15-25,000 miles depending on driving conditions—a typical filter removes between two and 12 grams of particulate matter
