3M Filtrete filters $14.95
Hi,
Found this on FW, 3M is having a sale on cabin filters. The filters are usually $24.95 but right now with the coupon, they are $14.95 each. Shipping is a flat $4.95 regardless of how many you order. There is a limit of 5 filters at a discount per order.
http://www.filtretecarfilter.com/Step1.aspx
Coupon code is CAC3Q
The discount doesn't show until after you give your credit card info, it shows in the summary before you confirm your order, so don't worry.
Choose the filter for a 2006 Camry, it's the same as the 07 and 08 RX350, not sure about the RX's before but easily checked at any website that sells filters.
I ended up buying 5 for my Prius and the RX350. These filters go for $23 at the local Autozone and Pepboys, made for Bosch by MicronAir. The ones at the dealer are made by Denso and cost about $30, but are pure crap, just a nylon/paper filter.
The 3M are quality, electrostaically charged filters. They are not carbon activated. I have yet to find a carbon activated filter for the Lexus because I think some European cars have those.
You also get a free car care kit with each order, includes a microfiber towel, glass cleaner, lint picker upper, etc.
Alex
Alex
Why is the Highlander not included, if the RX Filter is the same as the rest in the list? The size says 214x214x18 mm. I guess I can measure my Denso Filter and compare. Thanks!
I'm not sure if the cabin filter is the same on the Highlander as the RX, I guess we can look it up. I know that the engine air filter is the same in the RX as the highlander. I do know that the Camry filter is the same as the RX.
Alex
Alex
I just wanted to add, don't buy the filters with a checkcard. If you're smart though, you should know never to use a checkcard for online purposes. But anyway, they put like 4 charges on my credit card, I have a MBNA/BofA card and it shows the temporary authorizations, they did 4 of them. I sure only the real one will stick and the other ones will fall off but are they retarded or something. If you used a checkcard, you won't have access to that money for a couple of days.
Toyota parts
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
I did not, however, go by measurements. Only what the parts catalog cross reference said.
GO BUY THESE FILTERS NOW!!!!!!!!!!!!!!!!
I just got 4 of the 5 I ordered. They came by USPS Priority Mail individually packed, which I thought was a big waste of money because the postage for each was $4.60. Very inefficient. Still waiting for the last one, maybe a little delayed. Each filter came with the Car Care kit, microfiber towel, lint picker upper, glass towel. They forgot to include one lint picker upper but I forgive them.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
These are quality filters. They are hands down the best filters for a car I have seen. I bought the MicroAir and the Denso before. The MicronAir are the Bosch ones and also used on Honda OEM. The Densos are Toyota OEM and pure crap.
Have you tried them yet, do they exactly fit in terms of dimension.
Thanks in advance
More info about the product: During its service life—averaging 15-25,000 miles depending on driving conditions—a typical filter removes between two and 12 grams of particulate matter
http://solutions.3m.com/wps/portal/3...rior/Filtrete/
The past two times I've replaced my Toyota cabin filters they were made of some sort of nylon fiber. The paper filters were replaced by these newer nylon fiber types some time ago. Without knowing the size of particles the filters will trap I'm not sure how one can determine which is better or worse at filtering small particles such as pollen.
