RX330 A/C temperature Unstable
I have noticed that my 04 RX330 AC cold air is unstable. I had my AC temperature at 68-75 degrees and the air that output from the vent sometimes is pure cold and sometimes warm air. I never had this issue, but now it varies from mintues to minues. Any idea why this is causing it?
Thanks in advance for your help.
Split temp settings causes some of the problem and the bigger the spread between the two , the outcome is more pronounced. [Internally there is only one AC unit]
Salim
Salim
2007, ac, add, air, belt, clublexus, conditioner, conditioning, drive, e350, freon, kind, problem, refrigerant, rx330, temperature
