Mounting License Plate
So, my uncle bought a 2008 RX350 last Friday (Bamboo Pearl) at Tustin Lexus.
he's looking into mounting his license plate frame and bracket without drilling holes (NEW Car babying..)
I was thinking Automotive grade double-sided tape...but still afraid that might fall off?
SUPA Glue...just kidding, I have used Velcro and has worked on my Van many years ago.
i didnt put mine on....it looks so much better..and I live in NY...
You can try 3M VHB tape...that stuff they use everywhere...and its really strong.
it was on Modern Marvels....on this History channel....check it out...
Industrial grade velcro from Home Depot or Lowe's will hold the license plate for many years.
However, as a personal opinion, I would suggest a bracket that Lexus includes anyway and if you decide to take the license plate off later, just buy a few plugs to cover the holes (for example, www.bumperplugs.com).
-- Andrey
-- Andrey
You are required to have a front license plate in CA.
I told my uncle, that if Lexus of Tustin gave him one of the solid chrome Lexus plates (with no Dealer name) then he should go ahead and drill the holes, but yeah.
Considering the Velcro idea too
Tuan,
It seems you're talking about a brand new vehicle. How did you buy it without the dealer ALREADY having drilled and mounted the plate holder? I thought that was part of the law, too. That's what they told me.
If you were lucky enough to NOT have the holes drilled already, have them drill the holes, but you mount to the frame, after putting some kind of soft material on the back to prevent scratching the bumper. Use hole pluggers as has been suggested if you later decide you want frame removed.
........and zip tie, on a new Lexus? come on.
Tuan,
I recently drilled the holes and put a front plate on my RX 350, it was a hard thing to do but feel that a velcro attached plate would be easier to steal (lose).
something else for everyone in california to think about. the front plate should be bolted or screwed down onto a mount which is on the front of the bumper. so in any case unless you have mounted like that its illegal. so using double sided tape, zip ties, etc wont pass highway patrol judgement if you are trying to dismiss a fix it ticket. so i figure why the hell have it there in the first place.
I have seen some after market mount that the screwholes are actually below the bumper, and the mount extend from beneath, and hold the plates in the front.
My old Legend has that kind of plate mount. it doesn't look bad at all, and it does not leave screw hole on the front of the bumper.
maybe you can look into those....
I use: http://www.kjmagnetics.com/
Mount some behind the bumper and 3M tape some to your license plate. Extremely strong magnets.
