Dueler H/L Alenza
Hey guys, I need your feedback on the tire for RX, 18". According to TireRack, these are the most 'popular', Dueler alenza vs. Michelin energy vs. Goodyears vs. Kumho. To me seems like Dueler Alenza is the way to go, but I am concerned about its premature tread wear.
Follow this thread....
All I have to say.....Wohoo! I love these tires!![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
https://www.clublexus.com/forums/sho...ghlight=alenza
Don't write-off the Kumhos...
I was going to do the same deal with the Alenzas as the linked post describes, but instead decided to try the Kumhos.
Purchased through Tire Rack and installed by a local shop listed on the Tire Rack site, we got all 4 installed for around $480.
Compared to the OEM Michelins which had 41k on them, these tires rock! Road noise is significantly lower than the Michelins, and grip is outstanding. With the Michelins, I would get tire squeals whenever going through freeway interchanges at moderate speeds. These Kumhos don't break a sweat.
Out of Warranty
After a few weeks on the B'stones I think the big difference over the Michelins is the sidewall construction. Michelin has always had a very stiff sidewall - which contributes to their sharp cornering feel. Bridgestone retains 99.9% of that sharpness, but is a bit more compliant - producing a "thud" rather than a "bang" over a pothole. There is a difference in manufacturer's philosophy, if not technology - and Michelin came by theirs honestly.
The old Michelin "X" was one of the first radials sold in the US, and its ability to keep the tread planted flat on the road made it the secret weapon of a lot of autocrossers back in the day. Its downside was that with a thin sidewall, it tended to try to squirm off the rim under heavy cornering, even though the tread remained flat on the track surface. The trick was to blow up your "X"'s to about 40-45 psi to keep them from rolling under - stiffening the sidewall (and the whole tire) - and making it ride like it was solid rubber. Of course, suspension technology back in that era (Pleistocene) was limited - some vaunted "handlers" still used king posts ("sliding pillar" front suspension on the Morgan), and sports car manufacturers did not understand that the tire was part of the suspension system.
The over-inflation trick worked well at the track - but you wanted to let out some of the air before you drove your rat-racer home . . . to save your spine. Michelin responded by stiffening the sidewalls to achieve that elusive "sharpness" of handling, but as with over-inflating the tires, it came with a penalty - a rather harder ride than its contemporaries'. Ever since, Michelin's bias has been to produce a tire with a slightly stiffer sidewall to achieve that "sharp" road feel - without having to blow up the tire to dangerously high pressures. They have produced outstanding tires for many years that handle like few others - if you are willing to accept the slight penalty in ride comfort engendered by the stiffer sidewalls.
Now comes the low-profile tire "fashion" where everyone wants to make their grocery-getter look like a F1 racer. Narrowing the sidewall naturally produces a harder ride - thanks to reduced sidewall compliance over bumps. Michelin is again trying to find that "sweet spot" where the tire can produce prodigious cornering grip and still deliver a smooth ride. This time they have company - practically every major performance tire manufacturer is trying to do just that. In the end, the consumer is going to have to make a choice as to which manufacturer delivers the compromise between ride and handling that suits his own application and backside sensitivity. There are really no wrong answers here - it's a matter of choice.
We have Alenza's on our RX300. We do have a noticeable drop in fuel efficiency 1-2 mpg on both street and highway, but well worth it when compared with the OEM Goodyear Integritys. Handling, traction is significantly improved with these tires.
We also change from Goodyear Integritys to Alenza on our last car, what a diff. in traction. We did notice a little less MPG, but not 1 to 2 MPG. The reason why the Goodyear gets good gas mileage is that its rubber is so hard that it barely cause any friction on the road
thedavidfe
Wheels, Tires & Brakes Forum
09-14-16 08:01 AM
