lights on chime
Check the owners manual ... I have not tested it myself, but the lights are turned off automatically after a while.
Auto they shut off after a preset programmed delay.
Lock-lock (2 times) lock they shut off immediately.
Lock once in manual on mode ... they shut off in 10 (?) minutes or so.
Now if the battery is strong, it is not a problem but with a weak battery it may be too long.
It would be great if some one can confirm the above.
Salim
* In RX300 in manual mode I have left the lights on and the next morning they were off.
Salim
After turning off the ignition and all the doors are closed, if the headlights are ON or in the AUTO position, the lights can be programmed for the following:
1. Turn off immediately, when the vehicle is turned off and the driver door is opened.
2. Turn off in 30 seconds (Standard)
3. Turn off in 60 seconds
4. Turn off in 90 seconds
Thanks.
The only reason I ask was because the wife and I went to lunch and when I was walking up to the car, I used the remote to unlock it. Then I saw the tail lights on and assumed that I left the lights on the whole time. I guess when the remote unlocks the door, it turns the lighte back on???
I can't find the reference now, but I think they will shut off in an hour or so. Don't know if it's based on a timer or battery voltage. Having just replaced the battery a few days ago, I don't really want to test it to be sure . .
I can confirm that lights turn off (even in manual mode) after about 5 mins or so. That is true for both the headlights and interior lights. After all, we paid premium for our Toyota's, so it's a nice feature to have
I found it in that 10 lb. owners manual.
They turn off 30 sec. after the door is closed or instantly when the remote lock is used.
The 30 sec. is the default setting and can be changed in the personal settings.
