HELP ! Hatch Door hits garage and then closes again !
Old 11-28-07, 11:59 PM
toppower
toppower's Avatar
Default HELP ! Hatch Door hits garage and then closes again !
Hi Guys...I just picked up my 2004 Lexus RX330 Ultra Premium. The problem is that the power rear hatch opens to hit my garage door and them returns to the close position. How crazy is this?? I can use my hatch in the garage at all. Is there any way to adjust the open height of the power rear hatch? Is replacing the garage door my only option? I wouldn't even mind manually opening the hatch if this is an option.
Thanks for the help,
Al
Old 11-29-07, 12:17 AM
Booyah
Booyah's Avatar
No adjustment that I have ever heard of for the hatch. You must have a very low door in your garage? If you raise it by hand and just let it rest on your garage door it should be fine.
When you power it up it looks for resistance and its finding it on the way up then closing--normal
Old 11-29-07, 12:32 AM
RXSF
RXSF's Avatar
agree with booyah.
if you open it manually, it shouldnt close automatically when there is resistance. however, when you push the auto open button, then it will close upon resistance, safety issue.
Old 11-29-07, 01:29 AM
encore888
encore888's Avatar
I would recommend also you get some padding or something to protect your door when it hits the garage door, to prevent damage.
Old 11-29-07, 02:28 AM
AM1
AM1's Avatar
they should have a function that can adjust for height or speed. i hate how slow the door is to open or close
Old 11-29-07, 06:33 AM
The G Man
The G Man's Avatar
It might be easier to adjust the garage door so it will open higher.
Old 11-29-07, 08:52 AM
Lil4X
Out of Warranty
Lil4X's Avatar
"Doctor, doctor - my arm hurts when I do this!"
"Stop doing that."
If you are going to use the power opening feature, it has to have room to open fully. Otherwise, open it manually, don't open it in the garage, or trade for a taller garage. See? Problem solved!
Old 11-29-07, 10:52 AM
geko29
Super Moderator
geko29's Avatar
Is it hitting the part of the door that hangs down in the opening, or the part that's horizontal above the car? If it's the former, pull forward 2 feet. If it's the latter, you'll have to open it manually when in the garage, as the others said.
Old 11-29-07, 11:00 AM
RXSF
RXSF's Avatar
lol...and into the livingroom...
Old 11-29-07, 12:12 PM
steiner
steiner's Avatar
Al
Let me guess, you have the California-type gagrage door (the whole door is one flat piece). This type of garage door usually a foot or so lower than the roll-up type.
The garage has certain physical dimensions and the car has its physical dimensions too. If there is a problem, that's not because of the car is crazy, but because they are "incompatible". That's why some people I know would not buy a car until they can park it in their garage first. That is forsight.
Old 11-29-07, 05:17 PM
Tom H
Tom H's Avatar
I just back in. Hatch opens fully and I never worry about stopping too close to the garage door, which can prevent the hatch from opening at all.
Old 11-29-07, 05:34 PM
LexRexBlue
LexRexBlue's Avatar
My garage door hit, too but I discovered that its height was adjustable (the door not the car's hatch) so by moving the whole door up one notch my hatch could open. However, the garage door must be closed first! One day I goofed and backed up the car with the hatch open and the door open. I have a tiny vertical scratch right under the rear windshield wiper arm!
Old 11-29-07, 06:39 PM
geko29
Super Moderator
geko29's Avatar
Wow your garage is TINY. I don't consider mine large by any means, but in the usual parking position, there's a foot between the back of the RX and the door, and then 2.5 feet between the front and the cabinets, where there's another 2 feet to the wall.
Do they really make garages that are only 16 feet deep? So a Camry can touch both the front wall and the door at the same time?
Old 11-29-07, 09:02 PM
RXSF
RXSF's Avatar
well i didnt say mine was. but if he could just go in 2 feet more, than why would he even post this. that is the obvious solution.
javohio
05-12-23 09:54 AM
NXOwner
NX - 1st Gen (2015-2021)
09-11-15 11:24 AM
greg0723
02-15-11 05:11 PM
gentoo
Hybrid Technology
08-09-08 09:21 PM
spike owen
11-15-05 07:06 AM
Quick Reply: HELP ! Hatch Door hits garage and then closes again !
