Disabling the audible seatbelt reminder?
#31
Here is the instruction for reseting seat belt buzzers;
1. Turn the ignition switch to ON position
2. Press the ODO/Trip switch until the odometer display "ODO"
3. Turn the ignition switch off.
4. Turn the ignition switch to the ON position.
5. Press the ODO/Trip switch immediately (within 6 seconds) and hold it down for 10 seconds or more.
6. Continue holding down the ODO/trip switch and fasten the driver side seat belt.
7. Check that the odometer display either "b-on" or "b-off".
8. Press the ODO/Trip switch to change the display to "b-off".
9. Turn ignition switch off.
10. You are done.
10. You are done.
I just purchased a used RX330-2004 and would like to enable the seat belt warning noise. I guess the previous owner had it disable. Tried following the steps above, but no luck....any suggestions?
Thanks!
KC
#33
Thanks for the great info, it worked for me like a charm, even though I still always wear my seat belt.
However, I can not get the door lock settings to change using the procedure in the manual, putting it in park and N and hitting the lock button, etc. Anyone have luck with this?
Thanks
Thanks
