climate to metric
climate to metric
Just got my 05 rx330 home from the big apple! I have gained a lot of info from the site already but cant seem to find the answer to How to change my temp readings to metric and can you change the odometer reading to kilometers or am i stuck with the normal readings thanks
Welcome to CL, dgibby!
My RX is out Christmas shopping now, but I think the answer you are looking for is hiding under the Menu button. Select "Setup". You may not have noticed that this screen may be scrolled - I didn't until I had to poke around after a low-level reformat caused by disconnecting the battery for about an hour. There is a selection for "English" - "Metric" there (at least on my '04 330/Nav) that will set all of the functions of the center stack including both the nav system and the trip computer.
The odometer is another matter altogether and probably requires the participation of your dealer.
