Rx 350 Tires
Old 01-14-08, 07:41 AM
TIKINTJ
TIKINTJ's Avatar
Default Rx 350 Tires
Hi I was wondering if anyone else had this problem.
I have a 2007 RX350 with 18k and my tires are bad.
I have had them rotated 2x's already.
I did get run into a curb to avoid an accident a year ago when I first got the car and had to get an alignment but Lexus said everything was fine.
I have Michelin's and was told they wear out quickly.
Any one else have problems this quickly with tires?
Old 01-14-08, 08:05 AM
DakotaRX
DakotaRX's Avatar
I had the Michelin MXV4's on my 2005 RX330 Thundercloud in the 18 inch size. They did last me to about 38K, but at 18K they still looked fairly good. The MXV4's are usually warranted for only 25K and I've even seen some advertised with no warranty. So 18K sounds like you should have some tread left. I'm not sure what you mean by "bad". Tread is worn down to the wear bars, doesn't pass the Lincoln penny test or just not as much tread as you thought there should be a 18K, or just not very good traction in snow/ice. I had about 20/25K on my tires last winter and still got around fair. Even running in snow up to 8 to 10 inches one day and not too bad on compacted snow and ice. But when this winter rolled around and I had 38K on the MXV4's I got rid of them at the end of Oct. and switched over to the Bridgestone Alenza. Sure glad I did.
2005 RX330 Thundercloud, Thundercloud Mist, Gray/Black Interior with Black Birdseye Maple, NAV, ML, HID with AFS, Rain Sensing Wipers, Headlight Washers, Moonroof, Tow Package with OEM Hitch, 18 in. Thundercloud rims with Bridgestone Dueler Alenzas.
1998 GS300 Previous Lexus.
Old 01-15-08, 01:50 AM
AM1
AM1's Avatar
be glad your RX didnt come with eagle RSA's. mine lasted 28K, but i heard a lot of people wearing them out (eagles) in under 20K, im sure the michelins arent any better
Old 01-15-08, 11:18 AM
Grumpa72
Grumpa72's Avatar
My '05 330 has 36000 miles on it and I just had the tires off for a rotation. I measured the tread and it is between 6/32 and 7/32. Plenty of life left in these Michelins. Of course, this is my wife's car and she drives like a granny. I suspect that I wouldn't get this type of mileage from them if I drove it.
Old 01-15-08, 12:18 PM
Orzel
Orzel's Avatar
My Eagle RSA's barely lasted 16k miles and had the tread indicators showing, that's with regular pressure checks and rotation. Went with Michelin MXV's slightly oversize, as replacement and so far with about 16k miles they still look new and a darn sight better handling then the Eagle POS's were.
Old 01-15-08, 12:30 PM
The G Man
The G Man's Avatar
Are your tires wearing evenly, if so, then its not a alignment problem.
Old 01-17-08, 09:55 AM
TIKINTJ
TIKINTJ's Avatar
They Are Wearing Evenly Except 1 Is A Little Worse. Maybe It Is Defective. Although We Did Take A Couple Of Long Trips With The Car And This Summer Every Road I Took To Work Was Under Construction At One Time Or Another. Also I Drive "a Little" Fast Or So My Husband Says.
Thanks For All Your Responces
Old 01-17-08, 02:31 PM
lexuslover
MultiTasking Mom
lexuslover's Avatar
our OEM michelins lasted 50k. needless to say i replaced them with the same tires at costco. i'm very happy with the michelins.
Old 01-18-08, 06:10 AM
The G Man
The G Man's Avatar
If you push those tires hard, they will wear faster. They are performance tires and have pretty soft rubber.
Old 01-21-08, 01:28 PM
fud
fud's Avatar
Michelin's may wear out quicker but I'm pretty sure that it has one of the lowest road noise b/c they are softer. My entire family have always used Michelin's when it comes time to replace. You can't go wrong with Michelin's.
Old 03-13-08, 10:17 AM
billy44bo
billy44bo's Avatar
we have a 2005 330 with 47k Michelin's on it now. look to put on the Bridgestone Alenza
Old 03-13-08, 11:55 AM
johncdoyle
johncdoyle's Avatar
I replaced the Michelins with Bridgestone Alenzas at 36K. They weren't completely worn out, but winter was coming and there was less than half the tread remaining. In my opinion, the Bridgestones transform the car, firming up the ride and handling quite a bit. I did find it a bit soft with the Michelins, even overinflating them 2 or 3 PSI.
Old 03-13-08, 05:56 PM
billy44bo
billy44bo's Avatar
took the jump today and put on a set Bridgestone Alenzas. will see how well they do
Old 03-14-08, 09:20 PM
is4fsr
is4fsr's Avatar
you guys who have >30K miles are lucky. My wife's 05 rx330 w/ 26k miles needs a new set of tires w/in a month. She could probably still get 1 to 2 K miles. She drives conservatively. Even tire wear.
Will probably go w/ Michelins next time but it's gonna be costly.
Old 03-15-08, 09:51 PM
billy44bo
billy44bo's Avatar
I got my Bridgestone Alenza in town for 171 each less than the Michelins and the go for 65k with the first 3 years on them
Quick Reply: Rx 350 Tires
