Oil Change Interval
Old 01-28-08, 08:34 AM
Dinomon
Dinomon's Avatar
Default Oil Change Interval
Lexus recommends service every 5K or 7500 miles on the RX330. But I do mine every 5K but I put only 3000 miles every 6 months.
So my question is should I wait for every 5K miles to reach to do oil change or should I still change oil every 6 months even if I drove only 3K miles in 6 months? I would really appreciate some opinions on this. Thanks!!
Old 01-28-08, 09:52 AM
geko29
Super Moderator
geko29's Avatar
it's actually 5k or 6 months, whichever comes first. So you'd be 6 months.
Likely nothing too bad would happen if you waited till 5k, but I'd probably do it anyway, just to be safe.
Old 01-28-08, 01:51 PM
jfelbab
jfelbab's Avatar
In your example you need to service your Lexus every 6 months. Consult the OM supplement for basic maintenance for what items are needed when. There are several other items besides oil that are required at specific intervals and you can see them on the chart.
I just posted this quote from my 2004 RX 330 manual in another thread.
First determine whether your driving conditions warrant the 5,000 mile or the 7,500 mile oil change intervals. Next, consult the appropriate OM suppliment for the service needed. In either case you should change your oil at least every 6 months and sooner of you reach the mileage targets (5,000 or 7,500) before 6 months has elapsed.
This distinction is not just about oil change intervals but some other maintenance items as well.
Determining the Proper Maintenance Interval
Follow these guidelines to determine which interval to use.
5,000-Mile Intervals
Use 5,000-mile intervals if you primarily operate your vehicle under any of the following conditions:
•Extensive driving on unpaved or dusty roads.
•Towing a trailer or using a camper or car-top carrier.
•Repeated trips of less than five miles in temperatures below freezing.
7,500-Mile Intervals
Use 7,500-mile intervals if you primarily operate your vehicle under conditions other than those listed above.
Your vehicle is equipped with a dashboard light to remind you when the engine oil needs to be replaced. The light is amber and labeled “MAINT REQD.” When you turn the ignition key to the “ON” position, the light will illuminate for about three seconds to indicate that the reminder system is working properly.
After you have driven 5,000 miles since the vehicle’s last oil change, the light will illuminate for about three seconds and then flash for another 12 seconds when you turn the ignition key to the “ON” position. If you use 5,000-mile maintenance intervals, you should replace the engine oil at your earliest opportunity once the light starts flashing.
After you have driven 7,500 miles since the vehicle’s last oil change, the light will remain illuminated when you turn the ignition key to the “ON” position. When this occurs, you should replace the engine oil as soon
as possible, regardless of which maintenance interval you use.
Old 01-28-08, 05:15 PM
19psi
19psi's Avatar
the reason why you may want to change the oil at 6 months even if you're not at 5k miles, is that you obviously aren't driving very much, or are just doing short distances. this does not allow the oil to get to full operating temp, which burns off moisture and other contaminants which always collect in the oil.
Old 01-30-08, 07:56 AM
Dinomon
Dinomon's Avatar
Thanks.. Since my last oil change (6 months ago), I have only drove 2500 miles.. may be I should take it in..
Old 01-30-08, 06:18 PM
asianrage
asianrage's Avatar
I've always changed the oil every 5K. Which mean, l've changed the oil every 3 month.
Old 01-31-08, 06:29 AM
The G Man
The G Man's Avatar
19psi is right, if you drive low mileage, you need to change your oil every 6 months.
Nguyenrrr
LX - 3rd Gen (2008-2021)
17
03-08-15 11:32 PM
RX3302004
06-17-13 07:24 AM
jtrue28
12-29-12 02:25 PM
nowstime
09-11-08 05:47 PM
toneman
Maintenance
09-01-06 11:47 PM
Quick Reply: Oil Change Interval
