Mandyfig. I cleaned the blades on RX300 for a couple of years. And Ive had my RX350 for a little over a year. No problems with them becoming brittle or tearing.
look on the Trico website to find out where Trico Wiper blades are sold and get a 14-A, pop off the cover (as described in other posts), take off the old wiper put on the new one, it is an exact copy of the old one, I kept reading where others had difficulty finding a blade, this was $10 and an exact match.
For the rear wiper on my RX330, you get the base plastic cap off by just pulling out and up on the sides. It will "pop" loose. Don't worry... it's not broke. Once that base cap is off, you are able to flip the wiper arm out 90 degrees to work on it. Then simply "pop" the base cap back on when you are done.
